In between sizes...
[Closed] In between sizes...
[#9861605]
Every bike I’m looking at currently has me right on the border of the medium / large sizing. I’m 178cm (5ft 10’ ) average build with 31 inch inside leg. Bike will be a trail / xc hardtail with geo similar to Whyte 905..
I’m 50and my riding is pretty conservative, tyres will rarely leave the ground, so chuckablity not a priority.
I sat on medium and large whytes and both seemed ok (although there was virtually no stem) ..if a medium felt cramped I guess I could fit a longer stem.
Posted : 25/02/2018 12:01 pm
I've always found it much easier to adjust to a slightly too small bike than a slightly too large bike.
Posted : 25/02/2018 12:12 pm
I'm 5'11 and could ride large .. Ridden medium all my biking days never an issue 🙂
Posted : 25/02/2018 12:18 pm
Odd isn't it. You'd think manufacturers would put the middle of the sizing bell curve in the middle of their model range.
Posted : 25/02/2018 12:21 pm
Exactly...given that many people have to buy without trying it would be helpful!
Posted : 25/02/2018 12:40 pm
I’ve always found it much easier to adjust to a slightly too small bike than a slightly too large bike
Same!
Posted : 25/02/2018 12:49 pm
It really depends on body type (general proportions rather than overall height), rider fitness / flexibility, and personal preference.
The general consensus is that when you are right on the cusp between sizes you can get away with either with a few tweaks to cockpit, saddle position etc.
The problem nowadays is that a lot of bikes seem to be designed with a particular length stem in mind (i.e. as short as possible). A 6fter might be able to fit a medium frame with an 80 or 90mm stem but a bike with a 65 degree head angle is going to feel awful to ride with a stem of that length. There's a lot of snake oil standards kicking around the industry at the moment, but the long top tube / wide bars short stem geometry has even filtered down into most XC race bike manufacturer's designs so is generally accepted as a better way to build an mtb.
If you are between sizes, the only real way to size up a bike is to sit on one unfortunately.
Posted : 25/02/2018 1:08 pm
