Important pedal PSA
[Closed] Important pedal PSA
18 Users
I never knew that the left pedal has a little groove where it threads into the crank arm.
The amount of time I've wasted trying to attach the wrong pedal wants to make me weep.
null
Posted : 29/11/2021 6:12 pm
Read the instructions!
Different pedals have different systems. It used to be quite common that the left hand side had some knurling on it. Some even have an L on them
Posted : 29/11/2021 6:14 pm
I just look at the thread. A LHD thread is pretty obvious!
Posted : 29/11/2021 6:18 pm
Can be tricky if you're looking at it upsidedown, though.
Posted : 29/11/2021 6:22 pm
With enough for you can get them to go in either side.
Posted : 29/11/2021 6:25 pm
I wondered why one had tape on it then saw it was Crap Brothers.
Posted : 29/11/2021 6:35 pm
Can be tricky if you’re looking at it upsidedown, though
But not if you look in the mirror 😉
Posted : 29/11/2021 6:40 pm
Looks like the left hand one has a tapered thread too!
Posted : 29/11/2021 7:12 pm
Pedals are easy. They do up in the same way the wheels rotate when going forwards, and undo the way the wheels rotate when going backwards. Forwards = positive = doing up; backwards = undoing = negative.
Once you remember this then you can easily see which is which. Also, DMR pedals have L and R stamped on.
Posted : 29/11/2021 7:18 pm
I like this a lot. Thank you.
I do have my own method but posting it after reading this just makes it stupid.
Posted : 29/11/2021 7:29 pm
Do you need a "method"? The left pedal is left hand thread, the right pedal is right hand thread.
Posted : 29/11/2021 7:33 pm
I always think "they undo toward the back of the bike" which seems to work out easier in my head when the bike is upside down and back to front 🤣
I think the original poster had learnt something he/she thought was useful to pass on. It was a while after working in a bike shop that I realised that on cheap bikes that the left pedal had lots of milled lines parallel to the axle, some did have L/R but not all. Nobody told me, the shop I was in was good but not hot on training - even basic. We should appreciate the original poster passing the info on to help others!
Posted : 29/11/2021 7:42 pm
The amount of time I've wasted trying to pick at that groove thinking it was a pedal washer welded in place with old copper grease 🙄
Posted : 29/11/2021 9:10 pm
The biggest problem for me is the little nut on the end of the axle, some brands are reverse thread others use normal, its easy to ruin a nut or axle on the first service. The thread into the crank is obvious imo.
Posted : 29/11/2021 9:22 pm
That little groove saved me a crank arm when I bought a brand new set of deities that came with 2 RH pedals in the box.
Posted : 30/11/2021 9:45 am
It's more general than pedals - the same applies to LH threads on gas bottles etc. The nuts normally have a groove in them to denote LH thread.
Like this:
Gas fitting
Posted : 30/11/2021 10:09 am
I can't see what @zippykona means in the picture in the OP, but if a pedal doesn't have L or R stamped on the end (and most do IME) I just look at the thread.
That's worth knowing though @euain, ta.
Posted : 30/11/2021 10:46 am
