I'm going nich...
[Closed] I'm going niche - fixie my singlespeed advice
Right, I've decided I'm going to do something I've planned for years....
I'm going to run a rigid singlespeed (horizontal dropouts) with a fixed gear, and only run a front brake....very clean, light, minimalist....
....why, I don't know so don't ask.....
So, anyone done it? If so, what hub have you used and what gearing??? I'm thinking a Goldtec hub with double fixed so I can run different ratios (don't know where to source one), with a disc only rim (clean look - could never fit a rear V brake - even more niche) and running fattish slicks as I intent to use it for night rides on the lanes/fireroads round here - prob not singletrack...maybe run 32x14 or so....
Anyone prepared to make positive suggestions (I can imagine there will be plenty of negative ones!!!) ๐Ÿ˜€
Posted : 02/09/2011 5:02 pm
Fixies are fun ๐Ÿ™‚ Owned a Spesh Langster for a few years for riding around London.
I would stick with two brakes personally...
Posted : 02/09/2011 5:10 pm
I run flip/flop fixie/free with a v-brake. I try not to brake at all when riding it, Singletrack is fun... so don't ditch the back brake as you might need it. No poser points here.
Posted : 02/09/2011 5:30 pm
get a disc mount sprocket and flip the wheel round.
Posted : 02/09/2011 5:37 pm
 69er
Velosolo rear cog and what andyl said. Great fun, if a little different. Lose the rear brake, it's a whole new way to ride. My preferred set up for winter ๐Ÿ˜‰
Posted : 02/09/2011 6:30 pm
[url= http://www.velosolo.co.uk ]velo solo[/url] have the disc mount hubs and lots more lovely bits.
Posted : 02/09/2011 6:31 pm
What frame/forks?
I reckon 32x16 would be fine by the way, too low a gear feels pretty awkward. As said a disc mount sprocket on one side of a freehub hub/singlespeed hub will give you the flip-flop.
Charlie the bike monger (I think he uses STW) is a good person to quiz on such things if you want to make things more niche.
Also what are you fitting in terms of pedals?
Posted : 02/09/2011 6:39 pm
Why is this niche? My son cycles to school on said steed on a daily basis ๐Ÿ˜‰ . For the really clean look you need a hub brake on the front.
Posted : 02/09/2011 6:50 pm
If it's for road I run 40 X 16 and for fixed MTB 32 X 15. Love it....
Posted : 02/09/2011 6:52 pm
For the road/commuting I use a 42x16, but i like to climb hills. as for brakes, call me weak if you may, but Im not getting any younger, 37 and want to save my knees so I use both front and rear brakes... plus I like to go fast and on more than half a dozen times I have had to brake abruptly to avoid a very bad crash; so they have saved me.... many fixies around Melb dont have any brakes at all. Couriers,i guess they are one with their bike more, but all others ive seen go at about the speed of your granny on a mobility scooter, looking HIP, so slowing down is easy. Skidding; if your going fast you need abit of distance till you stop so your still going to crash into that car, person etc. all in all I wish I had continued riding a fixed since my first, a tricycle.. its so much fun and control is better not to mention neat when you pass a derailer.
Posted : 07/09/2011 10:54 pm
Do you have a sister?
Posted : 07/09/2011 10:57 pm
