If I run my forks o...
[Closed] If I run my forks open all the time are RC Pikes the same as RCT3's
 SOAP
Are the internals the same but without the open/pedal/lock feature.
Or are they shimmed different for high/low compression?
Posted : 26/07/2014 10:32 pm
 poah
yes, only difference is the pedal setting missing from the RC
Posted : 28/07/2014 9:22 am
They use a different rebound piston assembly.
Posted : 28/07/2014 4:06 pm
yeah if you look at the service manual it shows the difference, as above different damping unit. Therefoer I suspect there will be some difference between them in use
Posted : 28/07/2014 4:09 pm
Just took mine apart to reduce the travel, amazing how little oil there is in the lower leg damping side, none came out at all, 7ml came out the other side, guess there are maybe a few ml sitting in the leg still but will be making sure I get all 5ml in the damping side. Don't think these are going to tolerate long service intervals!
Posted : 28/07/2014 8:06 pm
