I used some conti X...
[Closed] I used some conti X-kings race sport tyres today and....
120 mm light hardtail with rockshox SIDS with ZTR alpine rims.
Riding at a fast race pace through Erlestoke.
2.4 on the front - not as wide a people said but not a lot of Clearance on the SIDS .
2.2 rear all setup tubeless. - went up first time and perfect. I did wash the tyres with meths first (tiny amount)
Pumped up 40psi - I know quite high
Was mixed terrain in a forest somewet routes, dry dusty trail and loamy forest, and some wet mud.
Tyres = wow the best I've ever ridden. Coming from 'race' tyres it's nice having loads of grip. these were very fast rolling too and light.
HiGHLY recommended!
Posted : 28/06/2012 11:05 pm
Hi Janesy,
You know you should not be riding Erlesoke as it is MOD land....:-)
Good to Hear you like X kings and they work over there, I used X king on the front over there, in the dry they are good, but with the wet weather I found they glogged a bit to much over there, So I got some Mountain kings and they are top all round tyre, for all but for dusty trails (becomes a little slow them)
Running tubless about 28 PSI
Posted : 28/06/2012 11:36 pm
Hi Rob! Yes yes It was only on the legal paths...
I used the Xkings as they were fast rolling so were still 'semi race' but with added grip. The 2.4 steam rolls everything and has totaly transformed my riding. I even got a KOM down salisbury hollow and as you know its loose rocky.
Only problem is - 0 mud clearance now on the rockshox even less than normal.
As for PSI - I'll have to experiment. although the rear when low pressure sqiums alittle so found it best pretty solid. Should be good next weekend at Bonty 24/12. You doing it?
Posted : 29/06/2012 11:07 am
 MSP
I like the x-kings, run the racesport on the front, but found it a bit lightweight for the rear and prefer the ptotection version there.
Posted : 29/06/2012 11:10 am
Wash the tyres with meths first?
are they dripping with mold release or something? I've never heard of anyone doing this...
Is this a common thing or perhaps a bit Anal?
40Psi sounds quite high to me for an MTB tyre now, especially run tubeless too, have you experimented with lower pressures at all?
Posted : 29/06/2012 11:32 am
 MSP
Its common for the continental tubeless ready tyres.
Posted : 29/06/2012 11:36 am
Cookeaa - No have not experimented with pressures yet - Popped the tyres on at 40psi to get the rim seated and went out for a ride. Even at that pressure there grippy (er) than my old tyres. Apen 2.25 exc.
As for meths.... - Read on the interweb about the mould repellent and stans not sealing, so why not, I had some in the garage.
I’ve also heard that the Race Sport don’t like tubeless but I’ve had no issues. I don’t know if that’s because of me cleaning them or they just worked.
Its common for the continental [b]NON[/b] tubeless ready tyres.
Posted : 29/06/2012 11:39 am
Agreed about the X-Kings, I'm running a 2.2 RS on the rear, simple to tubeless - scrubbed them with fairy and IPA first. Popped on without any hassle with just a track pump - didn't need to seat the bead first with a tube, and no washing up liquid on the rim required.
They're proper grippy, far more so than Rocket Rons - which have a similar tread pattern, and similar use - but the RoRo are dual compound - meaning the middle tread has little grip.
They're a bit more draggy, but I really don't care - the additional grip is just more fun.
Conti seem to have sorted out the tubeless issues - that or people were not scrubbing them, or inflating them correct in the first place.
Posted : 29/06/2012 11:52 am
