I still don't ...
[Closed] I still don't get why a tapered steerer adds stiffness to the fork.....
Oh.. it's one of these things where you think I'm asking something really stupid.. I see.
Well - perhaps I should ask another question - what's the internal diameter of a standard headtube with a 1 1/8 steerer?
Posted : 02/02/2015 12:33 pm
you can get it in a bit but most of the taper won't fit, people keep suggesting you can use something but you will slacken the HA and jack up the front end. Basically you will need something that looks like that funnel to fit it into the head tube.
Posted : 02/02/2015 12:36 pm
heavier stem
really....
From the Thomson website...
1/8? x 0° x 40 mm x 31.8 mm 155 g
1/8? x 0° x 50 mm x 31.8 mm 175 g
**From this we can reasonably assume a (none existent) 1,1/8 45mm stem would weigh about 165g**
1.5? x 0° x 45 mm x 31.8 mm 163 g
so actually 2g lighter
Given that both steerer tubes and stems become lighter with thinner tubes I reckon that a headtube would also be lighter than a tapered version - There are no stated weights for headtubes of course but the logic makes sense.
Bearings / top cap etc - yes I concede these will be marginally heavier although much stiffer and more robust.
Just for the record......
I don't actually give a sh*t about 2g on a stem, my bike is a hard hitting heavyweight and 2 grams makes bugger all difference to me. but I do feel that it is worth highlighting some of the misinformation touted by manufacturers in order to sell products; If only to get the weight weenies on board so I can finally UPGRADE MY FORKS!!
Posted : 02/02/2015 12:38 pm
another reason is that when you are making headtubes, the larger race at the bottom means it's easier to get the inner section of the carbon mould out (cos it's a cone not a tube)
(the design first appeared on road bikes and then the MTBs soon took up the new standard)
Posted : 02/02/2015 3:02 pm
Thankyou
For the first time a justification I can believe!
So they save money on the manufacturing process and make up some BS to convince their Alu steerer customers they are gaining an advantage
Priceless 🙂
Posted : 02/02/2015 3:09 pm
There's no question it's stiffer. It's basic engineering principles.
The question is whether that additional stiffness provides any real world benefit. IMO, on its own probably not that much.
However, that's kind of where the bike industry is right now - incremental improvements. A good bike from 10 years ago still rides well now but it is noticeable that all the small improvements in the last 10 years have made lighter, stiffer bikes that you can notice when switching from the 10 year old bike to a current one.
The small changes in themselves probably aren't real world significant for most people but the overall effect of all the changes together may be.
And that's where it really comes down to you as a rider and whether each small improvement is of benefit and how many of those small improvements are worthwhile enough in combination for you to splash out on a new frame/bike/wheels/fork/whatever.
(and no doubt there are manufacturing benefits to many of the changes too...)
Posted : 02/02/2015 3:18 pm
Thankyou
Except there's no carbon mold that comes out, or at least not a solid one .. how do they make frame tubes that have a BB / head tube / seat tube at the ends, or a long thin parallel seat stay?
Posted : 02/02/2015 3:29 pm
"I can finally UPGRADE MY FORKS!! "
You probably already can, to tapered forks. You just need to find a top cup for you headset that will run a 1 1/8" steerer in a 1.5" headtube. It'll probably be an internal cup one
By the same token there'll be a bottom cup to do the same job that'll allow you to use a straight 1 1/8" steerer
Posted : 05/02/2015 2:00 am
Page 2 / 2
