I-Spec B SLX Brake ...
[Closed] I-Spec B SLX Brake Lever + I-Spec B XT Shifter
Has anyone used the combination of I-Spec B SLX Brake Lever + I-Spec B XT Shifter (RH)?
It seems like there's a slot missing in the back side of the brake clamp where the square ended mounting nut should sit. The shifter pod clamp fits nice and snug to the back of the brake clamp but the screw provided only just bites. It feels secure but then the square end gets in the way of mounting the brake clamp as it is not flush.
Rather annoying since I made the usual I-Spec B / I-Spec mistake and then swapped the SLX shifter for the XT I-Spec B!
Posted : 27/09/2013 7:30 am
In case anyone is as silly as me. Don't disregard all the black bits in the fittings bag assuming they're outer ends. They're not! Small black cylinder plus tiny hex bolt instead of silver square end nut.
Posted : 27/09/2013 6:21 pm
