I really really rea...
[Closed] I really really really hate......my XT indicator window....
The sodding indicator window on my XT 1x11 shifter!
Please can you put me out of my misery and tell me where I can get a cover for it so I can remove it!
I only have a 4 days to get one including delivery...please help!
Shiny
Posted : 16/01/2017 2:37 pm
Take the window off, some shifters have the blanking plate clipped to the underside of them.
Posted : 16/01/2017 2:38 pm
[img] ?set_id=2[/img]
Did me fine.
Posted : 16/01/2017 2:39 pm
Take it off and put a square of gaffa tape over the hole
Edit: Cha****ng beat me to it
11 speed don't come with the cover (at least they didn't when I bought mine)
I just stuck some tape over it, has been fine
Posted : 16/01/2017 2:40 pm
[url= https://www.sjscycles.co.uk/gear-spares/shimano-deore-xt-slm780-base-cap-bolt-unit-right-hand-6uu-9809/ ]Took 2 secs with a google search[/url]
My first XT 11 speed shifter came with the crappy window installed with no blanking plate, the warranty replacement came with a blanking plate in the box. it appears that Shimano now provide them with a black plate.
Posted : 16/01/2017 2:41 pm
surely this millenium's least controversial entry to MTB room 101
Posted : 16/01/2017 2:42 pm
Yeah nothing screems 'Noob' like an gear window - I'm shocked Shimano still ofter them on their mid/high level groupset let alone add them by default.
I'm glad the come with a cover now, when I bought mine it was a case of buying the right one.
Posted : 16/01/2017 2:45 pm
It could be a lot worse, on the (few years old now) Deore shifters I have it required the judicious use of a hacksaw and then a bit of tape to remove them.
Posted : 16/01/2017 2:56 pm
Singlespeed?
Posted : 16/01/2017 2:57 pm
new 1x11 XT on new bike last week and was just wondering about this, so have ordered one from SJS link above, cheers STW ๐Ÿ™‚
Posted : 16/01/2017 2:59 pm
Cheers all, I had resurrected a post from 10 months ago and there seemed some doubt over whether it fitted hence the check with the collective oracle. Tape will not survive the monsoon season here in Malaysia as I have tried it before.
Have just ordered one and will have it delivered next week by my old man who is out for a visit.
Shiny
Posted : 16/01/2017 3:01 pm
I like my gear window. Tells me at a glance how awesome or weak/lazy I'm being on my local climbs. The only alternative is looking between my legs. ๐Ÿ™‚
I'll miss it on my new build.
Posted : 16/01/2017 3:08 pm
Bit late to the party ๐Ÿ˜‰
I started the old thread so happy to see that you were pointed in the right direction and can confirm it fitted fine. I'm a bit miffed that Shimano are now including them.
Posted : 16/01/2017 3:10 pm
yea I like the window thing, but I'm a noob
Posted : 16/01/2017 3:11 pm
Sharpie on the inside.
Or sharpie bimble at one end and gnar at the other?
Posted : 16/01/2017 3:15 pm
You know when I went 1 x 11 nearly a year ago I bought the window version as that's all I could find in stock, fully intending to remove it at some point.
It's still there, but I only just remembered because of this thread. I honestly can't say I've noticed it not not being there.
How awesome does that make you feel?
Posted : 16/01/2017 3:18 pm
do they definitely include them ? and if so are they attached somewhere ?
Posted : 16/01/2017 3:23 pm
They'll be in the box Iain, you wouldn't have got the box as it's a fully built bike.
Posted : 16/01/2017 3:44 pm
^^^^ cheers nobeer - will get it from Dales if they have it, though more likely never shipped from Giant...
Posted : 16/01/2017 3:45 pm
Even 9s doesn't point in a way that you could infer the gear you're supposed to be in from (even if you were a noob etc.). Unless the window has got a lot wider I can't imagine 11s is any better is it?
Posted : 16/01/2017 5:00 pm
I took it off and used a bit of that weird Sugru stuff to blank off the top of it (being careful to avoid the mechanism) - has survived for over a year without coming off unlike tape
Posted : 16/01/2017 8:20 pm
While accept that it's a matter of personal preference, whether to remove gear indicators or not, I'm curious how many of you "removers" have taken the numbers off the gear knob in your car ๐Ÿ˜‰
Posted : 17/01/2017 10:33 am
Why exactly does removing this make you better?
Posted : 17/01/2017 10:38 am
It doesn't make you better, it's just a pointless piece of equipment. You know if you're in the right or wrong gear for whatever you are doing, do you really look down and think 'Christ, I should be in a bigger gear!'....
A bit like looking at the numbers on your car gear stick, or the display on modern cars that tells you to shift up...
Posted : 17/01/2017 10:51 am
In a lot of cases it lets you fit the brake lever inboard of the shifter, putting both controls in the most ergonomic position.
So you can change gear and brake while keeping a firm grip on the bar.
Posted : 17/01/2017 11:26 am
I'm thinking of making mine into a snow globe.
Posted : 17/01/2017 11:42 am
I was disappointed the bar mount M8000 shifter came with the display and no blanking cover in the box (Feb 2016). I've recently taken a cog off the cassette and fitted a one up spacer behind the block to help with chain line issues (backpedal) so I'm only using 10 of the 11 clicks now.
Thanks to the SJS link above I've ordered a couple of the covers.
I do like the M8000 shifter and mech. The 11s cassette has been a disappointment compared to the 10s XT one though. At least the M8000 shifter and mech work with the 10s XT + an expander so it's not a total dead loss.
Posted : 17/01/2017 12:11 pm
I liked
Larry_Lamb - Member
- yeah he's so good he found you the 10 speed one when the OP wanted 11.
Nugget.
Posted : 17/01/2017 12:15 pm
As above - some form of rape tape over the hole. 1" Gorilla tape here.
Posted : 17/01/2017 12:18 pm
Does it even matter if it is there or not? Can't say I ever spend anytime looking at my handlebars anyway.
Posted : 17/01/2017 4:09 pm
I like having the window and I'm not a noob. I like having a quick idea of what gear I'm in, especially helpful in the dark as well.
Posted : 17/01/2017 4:19 pm
Surely you only have 10 clicks anyway so are not only using 9 clicks? ๐Ÿ˜‰
Posted : 17/01/2017 4:39 pm
Conversely I quite like mine!
On a leg burning climb it reminds me how many gears I have to go. I try to keep one 'spare', i.e. keep in 2nd, so that if I feel the need to give up (e.g. up a long fire road climb) then I still have one more gear to drop into
Posted : 17/01/2017 5:38 pm
SJS one ordered as above, but will only remove indicator and put on if I need to move dropper lever to the right hand side (arthritic left thumb, old git ... ๐Ÿ™ )
Posted : 17/01/2017 5:41 pm
joebristol - Member
As someone's already said, it depends where you want to put your shifters/brake levers, and what shifters/brake levers you are running.
Posted : 17/01/2017 5:50 pm
