I only need a 28mm ...
[Closed] I only need a 28mm socket!!!
How hard does it have to be to buy a 28mm socket or spanner? I only want to undo the top nut on my forks so that I can add a little oil to change the spring rate. Without having to resort to eBay, anyone know of somewhere in / around Windermere or Kendal?
Posted : 04/01/2014 6:48 pm
Tried halfords? usually have a good range of single sockets / spanners and their tools are really pretty good
Posted : 04/01/2014 6:52 pm
Big adjustable spanner from halfords/b&q/any tool shop
Posted : 04/01/2014 6:55 pm
Musgroves in Windermere or Middletons in Kendal. Both are 'old school' hardware shops that will probably be able to sort you out.
Posted : 04/01/2014 6:56 pm
Big adjustible from B&Q should do the job.
Posted : 04/01/2014 6:58 pm
adjustable for undoing the top nut on your forks! animal. buy a decent 6 point socket and machine the chamfer off so you have maximum engagement on the nut.
Posted : 04/01/2014 7:22 pm
Cromwell tools sell them,or they did when I bought mine
Posted : 04/01/2014 7:25 pm
Had a similar problem last year and ended up buying this [url= http://www.amazon.co.uk/gp/product/B001NYXC70/ ]Hex Box Spanner[/url] for about £6 which made servicing forks so much easier than with a normal/adjustable spanner.
HTH
Posted : 04/01/2014 7:28 pm
Yeah, Halfords will sell you a single socket in that size (I have one) - Ideal if you already have a 3/4" ratchet driver. (If not, why not?!)
Posted : 04/01/2014 7:31 pm
 sbob
I bought a whole socket set for that very purpose, is that not the Singletrack way?
Posted : 04/01/2014 7:34 pm
Did it cost more than the price of a fork service? 😀
Posted : 04/01/2014 7:44 pm
Any decent tool supplier should be able to supply a single ring spanner> I bought a 32mm ring spanner, known as the "persuader" to remove freewheels as I wanted something that fitted snugly over the tool and was longer than an adjustable spanner for leverage.
Posted : 04/01/2014 7:49 pm
As above, socket with the base radius ground off to give a proper square edge and full engagement on the shallow fork top nut.
Posted : 04/01/2014 7:59 pm
2nd for Cromwell, fair amount of choice [url= https://www.cromwell.co.uk/index.php?q=0&p=browse&c=03090301&ss=28mm ]here[/url] 1/2" all the way
Posted : 04/01/2014 8:02 pm
More or less same size as 1 1/8th" - perhaps that would be easier to find. 😉
Posted : 04/01/2014 8:22 pm
Yeah, that would be helpful, but not essential - at least for my Revs. It sometimes slips but is perfectly useable.
Posted : 04/01/2014 8:23 pm
+1 for getting rid of the chamfer from the socket.
It's very easy, nut and bolt through the socket to act as an arbor, spin it in a battery drill against a bench grinder wheel and you have the proper tool 🙂
Posted : 04/01/2014 8:28 pm
I'm all for bigger is better but 3/4 drive for a fork top cap
As above halfords are normal good for single sockets
Posted : 04/01/2014 10:39 pm
What difference does it make if its 3/4 or 1/2 .... 1/2 torque wrenches are muxh more common 🙂
Posted : 04/01/2014 10:45 pm
ISTR an old spark plug socket I had did the top cap on my Fox forks.
Posted : 04/01/2014 11:30 pm
I don't know if you're sorted but I have one of these in central Kendal if you want to borrow it?
[url= http://www.parktool.com/product/adjustable-wrench-paw-12 ]36mm Park Adj Spanner[/url]
Drop us a line on email, i'm in most of the day on Sunday.
Posted : 05/01/2014 12:29 am
Look on ebay there is a seller that sells machined down 28mm beta sockets for thi very job.. If you use a spanner etc and round off the hex it's a pita and looks terrible
http://www.ebay.co.uk/itm/Fox-Forx-BETA-6-sided-flat-Socket-for-32-34-36-40-Forks-/161148789170?pt=UK_sportsleisure_cycling_bikeparts_SR&var=&hash=item25853761b2
Posted : 05/01/2014 11:08 am
Amaizing folk think its the right tool if its painted blue. Its bike specific it must be right .
An adjustable spanner is not the right tool for anyjob.
Posted : 05/01/2014 11:12 am
£20 for a socket 😯
Posted : 05/01/2014 12:08 pm
trail_rat - Member
Oh i'm sorry your majesty, I'll fix my shit while you carry around a tool cab full of snap on for every eventuality.
I'm going to use it as a hammer today, I hope that makes your piss boil. 😆
I was just trying to help the man out.
Posted : 05/01/2014 12:36 pm
Cheaper at mojo
http://www.mojostore.co.uk/acatalog/Tools-1.html
I just use an aj though
Posted : 05/01/2014 1:19 pm
He's right though. Hammers are sometimes the right tool for a job. An adjustable is never the optimal tool - it's a passable substitute for some jobs but not this one...
Posted : 05/01/2014 1:21 pm
Of course it's acceptable. Not ideal, but if you're not a hamfisted oaf it won't leave a mark.
Agree they're never the perfect tool, but that's not why they exist.
Posted : 05/01/2014 1:24 pm
and IIRC theyre the best part of a tenner which is irksome when entire sets are £20. Got one from local Halfords FYI. Used an adjustable spanner once when I had no choice and I winced throughout, too much mechanical sympathy!
Posted : 05/01/2014 4:43 pm
£20 for a socket!!! Nope £20 for the right socket. Or you could wreck the very shallow hex on the damper cartridge on your fork then have to spend more trying to sort it out.
There's a reason people use decent tools, it's because they do a decent job.
Or use an adjustable and make a mess:-)
Posted : 05/01/2014 7:24 pm
When I was an apprentice if we were caught using a adjustable you were given a 10 count to start running then it was thrown at you as hard as possible!! There a right tool for every job so use it 👿
Posted : 05/01/2014 9:14 pm
 LoCo
We can supply you a machined 6 sided 28mm socket for £10 plus postage 😉
and for anyone who suggested it DO NOT use adjustable spanners on forks, it makes a horrible mess of them 😆
Posted : 05/01/2014 11:13 pm
Sorry but £20 for one socket is just stupid even if it is machined as LoCo has proved.....
Posted : 06/01/2014 12:35 am
Sorry but £20 for one socket is just stupid even if it is machined as LoCo has proved....wouldn't use an adjustable for that job either.
Posted : 06/01/2014 12:37 am
