Right, did't have the brake studs, which is why I couldn't do this the other night, but have them now...
CAn't believe this is causing so much hassle, I've fitted V brakes hundreds of times but I've can't work out what to do now.
The brake mounts have some sort of hard plastic/rubber plug in them that I need to get out before I can screw the brake studs in...but buggered if I can get them out!
They seem to have an internal thread that takes the brake bolt, but if I screw it in then I can't pull the plug out.
I can fit a blade between the mount and the plug, but leverage seems to just bend the plastic...I don't want to damage the plug incase I end up leaving a completely inaccesible piece in side the mount...
I've also tried to put a thin allen key in though the back of the mount and push but to no avail.
Help please! I don't want to damage the thread in the mount and I'm impatient and don't want to ring Isla bikes again!
Ta...thanks for reading!
anyone? please...pretty please! 😉
dremel or file a slot in the plug and screw it out anticlockwise with a flat screwdriver: plugs will doubtless be rammed in real tight so kids can't remove it and threads may be keeping them wedged in.
(if you have a steady hand and pin spanner you could do the same but drilling 2 tiny holes in the top at 3 and 9'o clock.)
...oh or file spanner flats onto the top sticky outy bit and use an (whispers) adjustable spanner.
Ok, screw a corkscrew, one with a fluted thread rather than a wound thread (like a spring), into the hole in the platic. Then use the corkscrew to haul it out.
Alternatively, nibble at the plastic with some side-cutting snips untill you can pull it out with those horrificly rusty pliers that lurk in your shed.
"Dremel", "file", "pin spanner"???
You assume this man has tools.
Imagine a toolbox bereft of anything other than a rusty 10/13mm combination spanner nicked from a volvo tool kit and some random a/f allen keys.
