I need a bit of hel...
[Closed] I need a bit of help with finding more gears.
Ok so set up is Cannondale prophet with Double (22T & 36T) and bash, 11T to 34T on back.
I keep on spinning out it top gear offroad (When it’s dry).
So as far as I can see it I have 3 options:
1. Dump the double and get a triple but I don't think I need 44T and 36T is fine then the trails are not bone dry.
2. Get at 38T for my double, but not sure if it would shifted from 22T or if you can even get them.
3. Put up with it, it will rain soon.
Posted : 15/08/2013 10:35 am
You're spinning out on the flat on a 36T front ?
Man you must be the bloody KING of Strava around your way !
Posted : 15/08/2013 10:42 am
 DrP
If you got a 38t, I've a 26t granny you can try to see how it shifts??
DrP
Posted : 15/08/2013 10:44 am
is it cadence rather than gearing?
Where does it say
Posted : 15/08/2013 10:45 am
[quote=weeksy ]You're spinning out on the flat on a 36T front ?
No some people don't like spinning at 100rpm off road.
Running 28/39 Sram setup 2x10 and having come from 22-36 feels good having dropped nearly 2kg from the bike and left single pivot for something proper.
Span out the 36 at times if I was on straight trails, the 39 is holding up very well even on the balls out bits at Roto last weekend.
Posted : 15/08/2013 10:48 am
http://www.sjscycles.co.uk/shimano-capreo-fh-f700-rear-cassette-hub-takes-capreo-cassette-32-hole-prod13433/
You need a Capreo hub ,it has a 9 tooth sprocket ,with a 36 tooth ring gives the same top gear as 44/11
Posted : 15/08/2013 10:56 am
Mostly DH segments but i did run out on all of this one:
http://app.strava.com/segments/1488421 it's flatish.
[quote> http://www.sjscycles.co.uk/shimano-capreo-fh-f700-rear-cassette-hub-takes-capreo-cassette-32-hole-prod13433/
You need a Capreo hub ,it has a 9 tooth sprocket ,with a 36 tooth ring gives the same top gear as 44/11 Cheers but new hub is to much of a faff.
Sounds good do you have a link so i can see what you have. Cheers
but if the front mech id for a triple it should be fine, Right?
DrP
Nope not got one and can't fine then on the web, only 38T for single set up.
Posted : 15/08/2013 11:19 am
