I fought Stan and w...
[Closed] I fought Stan and won (eventually)
I have had a battle getting my tires mounted on my ZTR Flow rims with just yellow tape and tubeless valve but did it in the end this is what I tried;
Track pump - not a hope in hell
bought a compressor,
tried again, no joy
covered everything in washing up liquid solution, still no joy even with compressor
took out valve and put in inner tube, this seated the tire
removed one bead and took out inner tube then put back tubeless valve
tried with compressor again - still no joy
removed core from valve, bit more washing up liquid solution and POP tire seated!!!
just need to put tubeless solution in now (through valve core)
Phew!
Posted : 11/07/2010 3:08 pm
I don't understand how people can have so many problems. I've done it with lots of different tyres, lots of different wheels, and never needed anything more then a track pump. The first couple of times I used washing up liquid and water, but not any more..
Posted : 11/07/2010 3:11 pm
When I did my Racing Ralph on ZTR 355's I nearly passed out due to vigorous pumping with ye olde track pump ๐Ÿ˜ณ
Clearly being married has depleted my pumpability ๐Ÿ˜†
Posted : 11/07/2010 3:16 pm
I have 355 rims and a non tubeless new nobby nic went up straight away with a track pump. It needed quite a lot sealant to hold the air. Also got a used Specialized Captain up with just a track pump - I'm not sure how you've struggled to get your up with a compressor!
Posted : 11/07/2010 3:34 pm
I've been having lots of "fun" with ghetto tubeless. I've tried Mavic 717s and Ritchey WCS with a Maxxis High Roller. I couldn't get either to seat with a track pump, although I had more luck with a CO2 cartridges.
I think one of the problems is the rim profile. On the Ritchey WCS the valve core rubber gets in the way of the second layer of tape., but on the Mavic there is a little trough for it to sit it so I get a better seal.
Next time I buy wheels I'll definitely buy something more suitable, but at the moment I'll have to make do with what I've got.
Posted : 11/07/2010 3:53 pm
I did the tube trick to get it seated and left it for half hour so the tyre took shape, popped it off one side removed tube etc. Filled it up with sealent and blew it back up with the compressor, First time too ๐Ÿ˜€
+1 - Def makes a difference ๐Ÿ™‚
Also pushing and hitting the tyre over the valve helps seat it
I just replaced a tyre this afternoon on Stans 355's with Kenda Nevegals 2.l - took a little time to seal little bead holes but with a compressor I got it up first time ๐Ÿ˜‰
Posted : 11/07/2010 5:47 pm
So it was less a case of fighting and winning, but actually following the instructions?
Posted : 11/07/2010 5:49 pm
never got one on with a track pump (i bow to your skill) but using a co2 inflater never fails ๐Ÿ˜‰
Posted : 11/07/2010 5:52 pm
Practice I think Jamie - When I first started I would use the term fighting but now I know the tricks of the trade its def easier ๐Ÿ™‚
Posted : 11/07/2010 5:53 pm
I think it really depends on the tyres if trying teh ghetto method. I used Larson TT UST's. Got them sealed but only using a compressor. They work really well and I doubt I'll ever go back to tubes.
Posted : 11/07/2010 6:18 pm
 Mike
This is why I stick to Mavic XM819's...simples ๐Ÿ˜‰
Posted : 11/07/2010 6:20 pm
To be fair I have Stan's Arches and they were a piece of piss to setup with some HR LUSTs.
Posted : 11/07/2010 6:21 pm
[i]This is why I stick to Mavic XM819's...simples [/i]
wot he said
Posted : 11/07/2010 6:28 pm
never had a problem with bontrager or kenda tubeless/ust tyres. inflated with track pump. sometimes had to hold it down over the valve.
Posted : 11/07/2010 6:41 pm
I don't think it helped that I was using non UST tires and they were 2nd hand so sent through the post half folded and half coiled up.
Posted : 11/07/2010 7:04 pm
"Mike - Member
This is why I stick to Mavic XM819's...simple"
Tyres fit to either pretty much exactly the same tbh.
Posted : 11/07/2010 7:18 pm
Just installed Ralphs and Rockets onto some new alpines. 20 mins total for the pair. Really really easy, installed the tyres on the rims high pressure for a a couple of days with tubes. Bit of soapy water, left half the bead on each tyre, track pump - easy peasy.
Posted : 11/07/2010 7:23 pm
s****s ........
Posted : 11/07/2010 8:22 pm
'Scuse my ignorance, but what is ghetto?
ps Hi Shortbread!
Posted : 11/07/2010 11:51 pm
Type cast but think along the lines of folks here and how they might want to avoid spending a fortune 'fixing' something, more likely to find a cheap alternative.
What it means here is that rather than fork out a few quid on proper tubeless setup we'd rather spend a fortune in cash and time trying to get something to work that wasn't designed to.
Better still:
Check the rims...
Posted : 12/07/2010 12:01 am
