Hydro Cross-Top bra...
[Closed] Hydro Cross-Top brakes
Haven't heard anything from Hope in a while, so giving up waiting for them.
I've currently got SRAM Force CX1
Has anyone read about compatibility with the newish Shimano BL-RX812-R levers?
If not, has anyone researched a reasonably priced Shimano groupset that will be compatible and not toooo much heavier than Force?
Posted : 09/05/2020 3:29 pm
SRAM use DOT and Shimano mineral so they definitely will not be cross compatible.
If you want hydraulic cross top I'd bite the bullet and buy GRX.
Posted : 09/05/2020 4:06 pm
 pdw
You can't mix Sram and Shimano hydraulics as they use different fluids.
Have just built a new bike with GRX 810 and am very impressed. Much prefer it to Force CX1 on my other bike. Merlin have had some good deals on it recently.
Posted : 09/05/2020 4:07 pm
Hope v twin user here
Posted : 09/05/2020 4:54 pm
They're not hydro top levers though and to be fair, I'd rather have drops only than those, having used them for a long time myself.
Posted : 09/05/2020 5:55 pm
Ok, understood about compatibility.
Better get saving then. Are the cross-tops compatible with any Shimano grx groupset?
Posted : 09/05/2020 6:11 pm
I see that the left levers are dropper-ready on some models too. That might the final push to change over.
Posted : 09/05/2020 6:15 pm
Theyโ€™re not hydro top levers though and to be fair, Iโ€™d rather have drops only than those, having used them for a long time myself.
I've got a v-Twin as well - specifically becasue when I built the bike it was for Three Peaks and back then that was the only option for cross-top levers. Used them for a few years but last time the bike got stripped down I removed the cross-tops and I'm just running the V-Twin now. The brakes feel far better - those cross-tops were a massive extra friction in the whole system.
As mentioned above the Shimano GRX uses mineral oil and SRAM is DOT fluid so if you want hydro cross-tops, your only realistic answer unless you can magically find a set of Hope anywhere (unlikely, they all went to team riders) is to go for a full GRX setup.
I was looking at that option for a while when I was rebuilding the CX but it would have been easier just to buy a whole new bike rather than screw around with all the changes required, especially since the drivetrain I have is perfectly good - the changes would all have been for the brakes.
Posted : 09/05/2020 6:31 pm
I've a pair of the GRX ones on a shelf waiting for a bleedkit to turn up. Will update on install and performance if I remember. Going to be fitted to 105 7020s and can't see why Tiagra would not work either, all BH90 hoses?
Posted : 09/05/2020 10:58 pm
OK panic over for me:
null
https://productinfo.shimano.com/#/com?q=st-rx&cid=C-453&acid=C-454
Posted : 09/05/2020 11:15 pm
Thanks for the chart @tinribz
Posted : 10/05/2020 1:11 pm
