Fitting hydraulics to an old bike with only cable guides. Has anybody got any experience with the A2z 1 or the BBB Hyroclamps for the top tube?
Looking for a nice neat solution without it looking really cr*p.
Any other ideas welcome, or am I best going with the sticky tab & cable tie option?
I;ve heard a few people drilling small holes each side of the cable guide and then using a small zip tie to go through and hold it.
I'm using these - they do the trick just fine
http://www.chainreactioncycles.com/Models.aspx?ModelID=28123
Havent bothered with any of the aftermarket clamps since I discovered that a cable tie and an O-ring is all needed. Pass the cable tie through the O-ring and then stretch the O Ring around the hydraulic hose and pass the cable tie back through it so the O-ring is wrapped doubled over hose. Attach the cable tie around the frame job done. Sorry about my description, but I don't know how to post pictures. If your not clear I can email a photo tomorow, it really works brilliantly their is a bit of flex to gueard against damage can be attached to any size and shape of tube. I think it looks really really clean and tidy compared to the aftermarket systems.
Cheers Bigsurfer.
What Rob said. Works fine for me. And on full-length gear outers too.
Cheers for that, never occurred to me but sounds a hell of a lot neater than what I've seen so far. Cable ties & o-rings it is then.......have to see what I can find at work now......
