I've rebuilt my Sram Roam 40 rear hub- it's been quite nice putting it all back together. Bearing press worked perfectly and rather satisfying.
When I try to fit the freehub, the ratchet doesn't work. The pawls and seal are flush and then it won't rotate, it's just fixed. I can't work out why this is happening. Everything seems to be rotating true. If I pull the freehub out slightly it will spin and click, but not once it's sitting flush..
Any ideas?
Posted : 14/03/2016 10:24 am
usually it's spacers either being missed out or put in in the wrong order. Hope Pro have a small spacer between the freehub and the wheel bearing, missing it out causes symptoms you're seeing.
Posted : 14/03/2016 10:29 am
I'd guess either one of the bearings isnt fully seated or theres are spacer missing or mixed up.
Posted : 14/03/2016 11:41 am
