My rear Crossmax ST doesnt appear to be freewheeling as well as it did. You would almost think the disc is rubbing slightly but its not.
I recently stripped and cleaned the hub but Im wondering if the bearings are dying.
What symptoms indicate a poorly hub bearing?
Thanks
P
Posted : 29/03/2012 10:24 pm
Hub bearing wear is usually flet by the wheel rim / hub feeling a bit loose play between hub and axle. But I have known mavic hubs slipping.
Posted : 29/03/2012 10:27 pm
