HT II, what actuall...
[Closed] HT II, what actually fails.....
Difficult to explain, hope you get the gist.... Changing the BB on my bike tonight, noticed that there are two types of bearing system on the stuff I have been using..
Hope BB, the metal bearing face actually contacts the crank spindle on a machined surface.
Shimano/Gub BB have a plastic insert that is both a bearing cover/shim. This plastic sits on the crank spindle where it passes through the bearing. Remove the plastic cover and shim insert and the bearing is obviously a rattling fit on the spindle.
The drive side of the bearing had play in it so I swapped it out. On checking it looks like the plastic spacer has worn or compressed, causing the play. The actual bearing looks ok. Its a shame to scrap the BB for the sake of the plastic part...
Any other peoples experiences? Can you find these plastic parts as new replacements anywhere?
Posted : 29/05/2012 10:45 pm
Plastic part won't wear unless the bearing has seized (at least at some point)
Posted : 29/05/2012 10:51 pm
superstar sells some top hat bushes - name angletech or something. SOmeone linked to them once from here
I bought some but haven't tried 'em yet
Edit: [url= https://www.google.co.uk/#hl=en&sclient=psy-ab&q=site:singletrackworld.com+%22top+hat%22&oq=site:singletrackworld.com+%22top+hat%22&aq=f&aqi=&aql=&gs_l=hp.12...92589.107874.2.111451.35.35.0.0.0.0.100.2189.34j1.35.0...0.0.POSRt1xwr3o&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&fp=45f95ee2823d921f&biw=981&bih=1374 ]here you go (1st result)[/url]
Posted : 29/05/2012 10:53 pm
rick - your expericence is the opposite of mine. It's usually the nds that fails first. Usually due to water and / or grit.
I've never had to replace a DS bearing before a NDS one.
They always go due to water / grit or at least a gritty feeling NDS.
BTW :
A: I Cant afford a those hope ones
B: Those SS top hats are significantly smaller than the HTII races / original top hats so I doubt they are any use. Like scaredypants - I bought them - but I've not had the reason to use them yet. So no real experience.
Posted : 29/05/2012 10:59 pm
CSW, I bought a GUB Ceramic from ebay, I'm sure its the plastic top hat thats the problem but they are not the same as Shimano so I couldnt swap them over... Tempted to try a bodge with ptfe tape....
Scaredypants, thanks for the link... I even posted about kaesae, he is just round the corner from us too...
Posted : 29/05/2012 11:03 pm
Apologies Rick - the GUB bit didnt register / click with me. Sorry - I've no experience with that.
Posted : 29/05/2012 11:14 pm
No problem.... the GUB bb from China uses the same top hat system as GUB, just a bit of a different shape around the bearing cover/seal. This stops it being a simple swap.
Posted : 29/05/2012 11:24 pm
I tried a GUB. Nice idea, but was made to the wrong dimensions! Ie when I fitted it to a 68mm shell, and therefore used all 3 spacers, I couldn't fit the crank. It did fit with only 1 spacer. Which means it wouldn't fit a 73mm shell bike frame. They gave me a full refund when I pointed this out. Which was nice.
I don't like the concept of plastic spacers, so its Hope FTW.
Posted : 29/05/2012 11:28 pm
I had the same with the GUB dimensions, but happy once I worked the spacers out for the 68mm shell.... I want to try and resolve the plastic top hat issue really..
Good they gave a refund.... gives me more confidence working with them in the future.
Posted : 30/05/2012 5:56 am
