How will I get on w...
[Closed] How will I get on with flat bars after risers?
I'm building up a winterbike. I got a an M4 Stumpjumper from here and am about to build it up. I got a pair of flat Race Face evolve bars to go on it.
Will I find a huge difference in the handling of the bike. I've not ridden a hard tail in years and every full susser I've had has had riser bars.
Should I stick to what I've ridden with before? or go flat? Whats the worst that could happen?
Posted : 23/10/2009 11:32 am
 nuke
To me the only difference between risers and flats is the bar height. Flats and risers can be the same width, sweep etc just at a different height. If you don't like the reduced height with a flat bar, stick some spacers under the stem or go back to risers.
Posted : 23/10/2009 11:36 am
If the sweep's the same as your riser bar you won't notice any difference.
I wondered if the rise had a 'spring' in it?
Posted : 23/10/2009 11:41 am
no 'spring', just a lot of marketing bull.
 nuke
[i]I wondered if the rise had and 'spring' in it? [/i]
I would imagine the material the bar is made of and whether its normal or OS will have a bigger difference
Posted : 23/10/2009 11:43 am
