How to tubeless my ...
[Closed] How to tubeless my drilled out carbon rims?
got some older pre UST Enve rims,
one of them has been drilled out for a schrader valve,
suffering a lot lately with punctures after none for ages,
what would be my best approach to tubeless this rim?
Posted : 19/12/2013 11:00 pm
stan's tape, joe's valve
Posted : 19/12/2013 11:03 pm
use one of the spacers you get in mavic rims for prest valves or use schrader valves for tubeless?
I had some Jo's Schrader Rim Strips, everything else I have has just gone with yellow tape and a stans valve
I think notubes used to make a valve with a wider base for just such a situation. Failing that, a notubes rubber rim strip would work. There may be other solutions but these are two I've used in the past.
Posted : 19/12/2013 11:07 pm
just to add I have 2 rims drilled for schrader running on Stans Valves with just the plastic insert (found in LBS parts pots)
Posted : 19/12/2013 11:09 pm
ah ok ill try, the drilled out rim is sleeved at the moment with a rubber grommet,
ill see how it goes
Posted : 19/12/2013 11:12 pm
Nowhere near as exotic but I converted my mavic rims with valves cut out of old tubes and the locknut done up really tight.
Posted : 19/12/2013 11:33 pm
Roval and Superstar valves also do the trick really nicely
Posted : 19/12/2013 11:38 pm
Use cut out valves most of the time anyway, can't see why this wouldn't work for schrader too.
Posted : 20/12/2013 12:09 am
... now your off tubeless can i recommend that you get some proper UST tyres and save yourself some grief regarding sealing with Stans etc
i fitted a pair of Maxxis Ardent UST tyres well over a month ago with the intention of injecting the stans fluid in the very next morning
... i still havnt got round to it and theyre still hard despite riding over a couple of hundred off road miles! 🙂
Posted : 20/12/2013 12:28 am
hi dad 🙂
Posted : 25/12/2013 1:46 am
 lerk
Schwalbe Schraeder tubes have a threaded outer and locknut, perfect for tubelessing!
Posted : 25/12/2013 9:32 am
I used a rubber cable grommet from an orange five swingarm, perfect fit, then use a stans valve as it fits better with the taper.
Posted : 25/12/2013 11:36 am
drill out the other rim and buy some no flats tubeless schrader valves £10.99 from crc.no need for them stupid fiddly presta valves.dont know anything about drilling carbon though
Posted : 25/12/2013 3:41 pm
