How to tighten spok...
[Closed] How to tighten spokes on Roval Traversee wheels?
Noticed that the one loose spoke on my rear wheel is now about 6 loose spokes. ๐Ÿ™ Although the wheel is still perfectly true I am guessing this is not ideal. However, I do not seem to be able to put any tension on them at all by simply tweaking the nipple with a spoke key and guess there must be a trick to it. Anyone care to enlighten me? They are straight pull spokes BTW
Posted : 10/07/2015 4:43 pm
Spokes are turning. You'll need to hold them while you tighten the nipples.
Posted : 10/07/2015 4:44 pm
Is it really that simple? I was worried there might be another part to the nipple that needs holding rim-side, i.e, buried under the rim tape.
If that is all it is then cheers. Will give it a go
Posted : 10/07/2015 4:52 pm
A lot of them use alu nipples so if they've had a bit of use you might also find they're seized, so fingers crossed on that. I always grip the spoke with molegrips wrapped in cardboard, this could possibly be a terrible idea but I'm yet to die
Posted : 10/07/2015 4:59 pm
lol, been doing some searching and a rubber pad in vice grips seems to be an accepted method. I will give it a go. My fear is that the threads may have pulled through though/stripped, in which case it is new spokes time!
Bl**dy bikes, one thing after the other...
Posted : 10/07/2015 5:01 pm
 Euro
All my nipples began to break/sheer around the same time (the wheels were just over 3 years old) so i'd advise caution when tightening. I got both wheels relaced with nipples that aren't crap recently...and just last week all the chainring bolts snapped too (same age as wheels). I don't think the big S use quality alloy or their red ano weakens them or i'm very unlucky or their alloy is shite or... ๐Ÿ˜‰
Posted : 10/07/2015 5:06 pm
Well happy to report that all spokes went back tight without problems using the rubber in a molgrips technique. Nothing scientific, just enough to get a ping rather than a flap! Will maybe get them trued and done properly next time I am in town, but hopefully some tension is better than no tension ๐Ÿ™‚
Cheers for the help guys.
Posted : 10/07/2015 5:58 pm
