We may always encounter some problems here and there in our daily life, Such as in our life and work, we may need to transfer photos from one computer to another. But the photos were to large to transfer or it was not the suit size we need. So what should we do?
Don't worry. I will bring you a good news. No matter whether you call it a photo, image, picture or graphic, the file size of your photo can sometimes prevent you from uploading, emailing or adding it to a web site. Here is a simple way to reduce the file size using a professional graphic converter software. It is the “AppleMacSoft Graphic Converter for Mac”.
By on. You may worry about how many photo formats you can reduce one time? This software can open and view more than 30 images formats. Such as JPG, GIF, BMP, PGM, PSD, PPM, DIB, ICO, ICB, PCX, PCD, PSP, PBM, PSG, WMF, TIF, TIFF, PNG, VST, VDA, EMF, WBMP, RLE, SGI, TGA, and more. So you needn’t care about it. At the same time, you can also batch processing hundreds of photos while keeping the photos quickly and quality. The most attractive is you can save and write more than 10 mages formats including GIF, JPG, PNG, DIB, BMP, ICO, TIF, TIFF, WBMP, TGA, WMF, EMF and more. It also support more than 50 filters like noise, soften,contrast, blur and so on.
Step by step, Let's start The easiest and fastest way to resize photos on your Mac.
Step 1: Install the “Graphic Converter”
Download for Mac:
http://www.applemacsoft.com/graphic-converter/index.html
Download for Windows:
http://www.graphic-converter.net/easy-graphic-converter.htm
Step 2: Add the photos you want to reduce.
Step 3: Select the output size.
Step 4: Choose the output folder.
Step 5: Start conversion then it will be finished.
Free to try it right now !
