how to reduce oil l...
[Closed] how to reduce oil level in my fork
[#4205590]
woundering how i could reduce the oil level in my marzochi all mountain sl 2 im pretty sure this is the reason i cant get full travel. the guy i got them off tole me "ive just put some new oil in them)
Posted : 28/07/2012 11:10 pm
 GW
pour some out? is this a trick question?
Posted : 28/07/2012 11:11 pm
no lol. wear do i puor from? top or bottom of fork? left or right leg?
Posted : 28/07/2012 11:13 pm
It could be more complicated than it first appears. I asked a simple question about fork oil lastnight and discovered that it might not be quite so simple.
What weight oil did the guy you got them off, put in?
Posted : 28/07/2012 11:14 pm
not a clue. but im only getting about half travel. and this is most likely cause of the problem.
Posted : 28/07/2012 11:16 pm
well thats what all the evidence so far points to. im only getting half travel
Posted : 28/07/2012 11:17 pm
not even got a clue how much and wer the oil goes
Posted : 28/07/2012 11:19 pm
 GW
[b]What weight oil did the guy you got them off, put in?[/b]
..and now you're an expert? 😆
find a service guide for the fork online Tony.
stripping and re-filling the damping oil in a fork is not complicated or difficult but you need to know oil levels/volumes and weights.
Posted : 28/07/2012 11:22 pm
i can only find a owners manual on marzochi's website and google serch ect. and it tells you next to naff all. non of the important stuff anyways
Posted : 28/07/2012 11:30 pm
No. just passing on the expert opinions of others... 😆
Posted : 28/07/2012 11:33 pm
 GW
You're looking for something like this...
but obviously for the year of fork you have
Posted : 28/07/2012 11:35 pm
nice one mate. im pretty sure these are same as mine other than mine have 20mm and these are qr. im thinking ill just empty the only out and just replace around 80% of it and see if this makes it any. if it makes it better/fixes is i know its oil levels
Posted : 28/07/2012 11:41 pm
 GW
try that but remember too little oil and a fork may top-out from lack of damping.
Posted : 28/07/2012 11:44 pm
And result in a silly accident. 😕
Posted : 28/07/2012 11:45 pm
watsontony I think spellings for some of your words wrong.
Posted : 31/07/2012 1:00 am
Undo the top caps and dip in a cloth
cloth soaks up some fluid and hey presto
Posted : 31/07/2012 3:03 am
If you're going to go to the effort of pulling the forks apart, I think youd be best off replacing the fluid with the right amount of the right weight. After all, the fork is signed to run with a particular volume and type in it and if you start "fiddling" you might not ever get to the bottom of this half travel mystery.
Posted : 31/07/2012 8:54 am
 DrP
Look via the Windwave website - they often have Marz service manuals.
As has been said - dump all the current oil, and replace with the correct volume of the correct oil....
DrP
Posted : 31/07/2012 9:00 am
