How to mount one of...
[Closed] How to mount one of these on your lid
http://www.dealextreme.com/details.dx/sku.12325.
Hi all any ideas or products to use one of these as a head tourch.
cheers gang.
Posted : 02/12/2009 9:05 pm
One of these - http://www.dealextreme.com/details.dx/sku.12000
Posted : 02/12/2009 9:14 pm
I use one of these on my helmet:
[url= http://www.dealextreme.com/details.dx/sku.12000 ]dx mount[/url]
Its [i]just[/i] like a twofish lockblok (which I also use) but parralel rather than right angles and costs less than half as much. ๐Ÿ™‚
Posted : 02/12/2009 9:20 pm
cheers guys. stw. instant info.
great here isn,t it.
Posted : 02/12/2009 9:22 pm
Made a mount for my old torch using some Fimo (bake in the oven plastacine type stuff) to give it a moulded base and a length of velcro to hold it in place.
Posted : 02/12/2009 9:35 pm
heres mine
think its the same dx mount quoted above..?
Posted : 02/12/2009 9:40 pm
just reading the reviews on this light.
do i need protected batteries for it?
Posted : 02/12/2009 9:43 pm
yes
Posted : 02/12/2009 10:50 pm
I just hold the head torch on my helmet with some rolled up bits of old innertube to provide some compliance/cushioning against the helmet and two re-usable cable ties. I alter the tension between the front & rear to set the angle correctly.
Bit of a faff sometimes though so perhaps a proper mount would be a more sensible option.
Posted : 02/12/2009 11:08 pm
same style as stumpy01, but use a short length of foam pipe lagging to give a bit of vibration protection along with the cable ties.
works a treat!
Posted : 02/12/2009 11:19 pm
[b]NO! Dont get protected batterys for it.[/b]
The last thing you want is the protection circuit kicking in when you're flying down hill.
Get non-protected and you'll be fine, just change them when the light output starts to get low, usually around an hour.
Posted : 02/12/2009 11:59 pm
just been i touch with the god smudge and defo protected batteries are the way to go for this light.
Posted : 03/12/2009 12:38 am
i have got trustfire protected 1850's (the blue ones) and they go noticeably dim way before they cut out altogether.
Posted : 03/12/2009 5:13 pm
jw.is that a bit of a pain in the arse?.
just bought them.
Posted : 03/12/2009 5:16 pm
I secure mine with two big fat laggy bands, adjust the number of times you wrap them round to adjust the angle....
Posted : 03/12/2009 5:21 pm
Big lump of blue tack [moulds to shape of helmet and then press torch to other side]and a velcro strap. Have used it for years with our helmet cam with no problems
Tracey
Posted : 03/12/2009 5:23 pm
