How to measure rim ...
[Closed] How to measure rim wear on V-braked bike
On my girlfriends v braked bike I can feel a bow in the rim with a finger, is this enough to need replacing or should I measure it somehow?
Bike is ridden on Sustrans type routes and roads and don't want to spend money and time (rebuilding the wheel) unecessarily; nut equally don't want an exploding wheel.
keppoch.
Posted : 05/02/2010 11:48 pm
Everyone has discs now then eh 😉
keppoch
Posted : 06/02/2010 6:37 pm
It's hard to tell without a set of calipers and removing the tyre. An experienced mechanic/bike person would be able to guess given a close inspection. Lots of rims now come with wear indicator grooves built in. I'm guessing hers doesn't - or it's worn right past it. A fairly basic wheel will set you back mibbe £40. It is worth it?
Posted : 06/02/2010 6:40 pm
When I was running cantis / v brakes the way to tell was:
slight concave to rim = worn
noticable concave to rim = very worn and very easy to dent / crack the rim even without flatting the tyre.
Bear in mind the walls of the rim are only something like 2-3mm thick.
Posted : 06/02/2010 7:09 pm
depending on how often you ride and in what conditions, will affect the remaining lifespan of the rim.
I used to get 3 to 4 months from a rear rim, from brand new to sidewall failing, riding regularly in Peak District gritty winters
Posted : 06/02/2010 7:12 pm
Straight edge accross the rim braking surface so you can measure the concave wear. More than 0.2mm wear, (use a feeler gauge) and you should think about a replacement.
Hope that helps,
A
Posted : 07/02/2010 3:12 am
