How to knock the be...
[Closed] How to knock the bearings out of my front hub?
I've got some replacement bearings and I've taken the end caps off but there's a metal tube inside between the bearings which is stopping me from getting any purchase with the drift. Any ideas on how to get them out?
It's a front hub, cartridge bearings obvs.
Posted : 08/01/2017 4:43 pm
Which brand hub?
I just had to work out on a WTB hub - the inner 'tube' could actually be pushed to one side with a firm push on a long lever - that then gave me enough purchase on the one bearing to batter the thing out. As soon as it moved a mm, I could then move the tube easily and use a drift.
Posted : 08/01/2017 4:49 pm
This'll do the trick. A thin plastic tyre leaver usually does the job.
Posted : 08/01/2017 5:00 pm
 Del
Or it'll have a lip on the inside, so just **** it and it'll take the bearing out with it.
Posted : 08/01/2017 6:03 pm
job done, thanks!
Posted : 08/01/2017 7:27 pm
