How to get rounded ...
[Closed] How to get rounded bolt out of a Thompson stem?
Posted : 02/12/2019 10:48 pm
As mentioned cut through the gap..then drill from the stud side(NOT HEAD SIDE..this is under tension on the bike wont go through right..) then undersized drill the file out remnants if neccisary only if it doesn't unwind with a extractor..clean threads copper slip/grease new (4mm!!) Allen bolt or better a t20/25 then that almost certainly wont round out even when stuck..also try bashing it with a soft hammer(breaks the bolt thread tension a bit)..
Posted : 03/12/2019 2:11 pm
As mentioned cut through the gap..then drill from the stud side(NOT HEAD SIDE..this is under tension on the bike wont go through right..) then undersized drill the file out remnants if neccisary only if it doesn’t unwind with a extractor..
Username checks out.
I know what to do and I'm having a hard time following that.
Posted : 03/12/2019 4:24 pm
Page 2 / 2
