How to fix steel fr...
[Closed] How to fix steel frame mech hanger?
I have a Dialled PA and the mech hanger appears to be bent out of shape. As it is part of the frame and not a separate component can this just be bent back into line or does it need specialist treatment?
Posted : 04/04/2011 4:06 pm
Depends on the extent of the bend. Much like a paperclip, if you bend it a tiny bit, you can bend it to and fro 10-15 times, but if you bend it 90 degrees you might get one chance at it.
Posted : 04/04/2011 4:08 pm
you can just do it with an adjustable spanner if you're careful but, personally, I'd go to a shop as they should have kit to measure it's lined up again properly.
Its not to bad, however I think maybe the LBS would be the best option if they can measure to make sure its lined up properly.
Posted : 04/04/2011 4:19 pm
 jond
A basic version of the alignment check tool is only something like about 15 quid or so (I bought one about a year ago) - but a bike shop ought* to have more practice at bending hangers back.
*or possibly not, since a lot of bikes now sold are ally and they'd probably just chuck a new hanger on...
Ok, I lied - 20 quid from wiggle:
http://www.wiggle.co.uk/cyclus-gear-hanger-alignment-tool
Posted : 04/04/2011 6:01 pm
It's quite hard to do it well with an adjustable spanner, I can do it but it's a pain and I'm not bad at this sort of thing. But what works better is a Shimano (or similiar) axle- the thread is the same and because it juts straight out it's very easy to tell if it's all straight.
Posted : 04/04/2011 6:13 pm
I've managed with two big adjustable spanners before, but bike shops will have a nice tool.
Posted : 04/04/2011 6:14 pm
