How tight is too ti...
[Closed] How tight is too tight?
since changing the chainset on my singlespeed, the chain ended up a bit slacker (obviously slightly smaller chain ring)
So how tight is too tight for the chain, I presume there should be a little slack......but how much exactly? It's a slidey dropout with chaintugs.
Posted : 20/06/2011 6:51 pm
If it's a deep purple colour at the end...
Posted : 20/06/2011 6:52 pm
 flip
Till they turn blue?
Posted : 20/06/2011 6:53 pm
No need Crikey no need... ๐Ÿ˜ฏ
Stop squeezing it.
When the BB starts moving towards the rear wheel, it's too tight!
Posted : 20/06/2011 6:54 pm
If the chain stays on it's tight enough. I only tighten my chain when it falls off.
Posted : 20/06/2011 6:57 pm
slack enough so the chain can wobble about 1cm up and down when no load on it.
Posted : 20/06/2011 6:58 pm
If you used a superstar rear cog like i did, it'll be tight for half it's rotation, then slack for the 2nd. So just find a happy medium! ๐Ÿ˜‰
But i usually aim for about 1-1.5cm wobble.
Posted : 20/06/2011 7:29 pm
If your knuckles are turning white then your doing it wrong.
Posted : 20/06/2011 7:31 pm
