How often should I ...
[Closed] How often should I change my stem?
As above really. The stem on my bikes 5 or 6 years old, the bike's used several times a week so the stem's had plenty of use. The stem looks fine, but does bits of kit like this have a use by date?
Posted : 28/06/2017 1:47 pm
Same as your handlebars and seatpost. And cranks. And brake levers, etc... If it ain't broke and you are happy with it, it's probably fine.
Posted : 28/06/2017 1:49 pm
steezysix - Member
Handlebars yes, stem not unless crash damaged. I've only swapped stems when replacing old bars and standards have changed.
Posted : 28/06/2017 2:34 pm
You're allowed to change it any time as long as its for a shorter "more Enduro" one. ๐Ÿ˜€
Posted : 28/06/2017 3:05 pm
Incorrect, you're also allowed to change it to a 140mm, -17 degree stem. Either go long, or go short, 50 - 120mm is simply not pro.
Posted : 28/06/2017 3:08 pm
It's a 45mm jobie so plenty enduro enough for me. Going up to 140mm would be entertaining right until I had to go round a corner!
Posted : 28/06/2017 3:41 pm
 rs
better change the frame while you're at it, just to be safe...
Posted : 28/06/2017 4:17 pm
Is it a Thomson? Everyone else's stems last basically forever but they consider stem faceplates to be a consumable.
Posted : 28/06/2017 4:32 pm
rs, I have changed the frame after breaking the last one. It lasted 18 months so in comparison the stem's doing well ๐Ÿ˜€ nope, not a Thomson stem. An old Sunline something or other
Posted : 28/06/2017 5:33 pm
I've got a Sunline V1 I bought used with no bolts. I was told the heads had rounded off and that they were alloy?! If true then they would be the only part I would worry about.
I cleaned & checked the threads in the stem then used 12.9 high tensile steel bolts and it's just fine
Posted : 28/06/2017 5:45 pm
lazlowoodbine, I think that's what mine is. They're definitely steel bolts though as I swapped them out as they were rusting
Posted : 28/06/2017 5:50 pm
