How often do you ge...
[Closed] How often do you get your fork serviced/bushings replaced? Is 16 months 'short'?
I am using a Magura Menja fork at the moment and am quite happy with it in terms of performance. I last had it serviced about 16 months ago, but the bushings are getting a little sloppy already. Probably a bit more life in it yet, but likely only a few months.
So I was wondering, is this normal? How do other forks compare in terms of service intervals?
I have never really owned a 'high-end' Rockshox/Fox. I had a RS Tora once, and that seemed pretty bomb-proof.
Posted : 09/05/2011 8:33 am
every 12 months here. Some will say that is too often, but so far mine last well. Every ride I wash the bike, dry and wipe off the stanchions with a soft towel and give a liberal squirt of Fork Juice onto both stanchions and pump it a bit. I don't do DIY lifting of the seals/foam though as I reckon I'd end up scratching something. Fox 32's and Reba's
Posted : 09/05/2011 8:38 am
the mrs fox f100 floats lasted 10 months before needing serviced - rebound rod snapped - shes not a heavy nor a hard rider so dread to think what id have done to them !
my rebas have had oil changes but never a new set of bushes nor seals - in 6 years - my sids lasted 6 months before new lowers , seals , internals ..... but that was a warrenty issue
Posted : 09/05/2011 8:39 am
Sounds about ball park for a service. Were the bushes replaced at the last service? They're not normally done unless they need it. How old is the fork in total?
Posted : 09/05/2011 8:41 am
Interesting. The Maguras are very 'plush', but I have a suspicion that means they use a larger (looser) tolerance on the bushings that makes them wear quicker.
EDIT: Yes, the bushings were replaced last service. Total age of fork is probably about 2 years. Bought second-hand, bushings replaced immediately.
I've never replaced fork bushings or had them done. Lower leg service (a 20 minute job) happens every couple of months. Damper/spring service once a year.
RS forks for the most part.
Posted : 09/05/2011 9:22 am
Jon Edwards +1.
A mix of Fox (although not these days) Rockshox and Manitou.
I have had TFT adjust a couple of sets of bushes so they fit the stanchions a little better.
Posted : 09/05/2011 9:52 am
The bushings on my 2010 Rev's seem to have worn out in < 12 months from new! Bit dissapointed since it costs a fortune to get them replaced/resized and you can't do it at home.
Last set were 3 years old when i sold them and bushings were fine.
Front rear shock service easily comes in at > 200 quid. With wheel bearings, pads, drivetrain etc.. it costs more than a car to service!
Has anyone worked out a pence per mile calculation?
Posted : 09/05/2011 10:01 am
I ride a set of pre-2008 Marzocchi's, so i only have to service them every decade.
2005 Z1's, one oil change, and one bushing change. Still riding buttery smooth.
Posted : 09/05/2011 10:11 am
My Menja's are abotu that old, but I've only ever changed the oil and cleaned them out ever ~4 months, and a squirt fo fork juice before/after every ride. Just about need new seals now.
Posted : 09/05/2011 10:19 am
its a nightmare even trying to get the tools to change the fork bushes.
Posted : 09/05/2011 10:26 am
never replaces a set of bushings but I do do the oil change fairly regulalry
Posted : 09/05/2011 10:28 am
mine was serviced about 24 months ago according to the previous owner.. and I've noticed in the last three months that I really really need the bushings done..
hopefully I'll get round to sorting it this year sometime..
Posted : 09/05/2011 10:52 am
well heres the instructions
it doesn't look that difficult, just need the expensive looking tools!
We need some sort of group buy/loan scheme or something.
Posted : 09/05/2011 3:40 pm
