how much is a Fox ...
[Closed] how much is a Fox Vanilla Rc rear shock with 500lb spring worth?
i know its annoying but i have to ask so as to avoid offence when i come to sell.
cheers
Posted : 05/03/2010 3:19 am
come on....i know its annoying but id appreciate it
Posted : 05/03/2010 12:46 pm
they used to be loads on fleabay, might be your best option.
What size/year out of interest?
Posted : 05/03/2010 12:48 pm
£11.22
Posted : 05/03/2010 12:54 pm
If it's a pro-pedal one and in good condition then £30-40.
Posted : 05/03/2010 12:57 pm
yup its pro pedal, 7" travel, 2004.
is that all i need to say to describe it?
is there something about stroke or something used to describe it?
(500x2.8??)
cheers for the ideas
Posted : 05/03/2010 12:58 pm
is that all?
Any chance it's a 200 x 50 pro pedal is it?
[EDIT] Doh, no use to me..
[i]is that all i need to say to describe it?[/i]
In an advert you'll want this info: overall length, the stroke, & the spring weight (the spring stroke is kinda redundant, as they use 2.28 springs on 2.0 stroke shocks)
Posted : 05/03/2010 1:02 pm
£50-£60 I'd say, a Van R would fetch about £40.
You will want the shock length measured from eye to eye an also the shock stroke - the length of shaft visible when the shock is uncompressed.
Posted : 05/03/2010 1:03 pm
Shock length-216mm
shock stoke-68mm
that sound right to you?
cheers
Posted : 05/03/2010 1:15 pm
That will be 216x64mm or 8.5x2.5"
Posted : 05/03/2010 1:24 pm
thank you kindly 😀
Posted : 05/03/2010 1:36 pm
if you had a 350lb spring i'd be interested!
Posted : 05/03/2010 2:06 pm
sorry only have the 500
Posted : 05/03/2010 2:19 pm
