How much does your ...
[Closed] How much does your road bike weigh?
 mrmo
if i have decent tyres and no lights, no mudguards etc, which is what it has on it for now, it comes in at 19lbs.
at moment probably 22-23ish.
Posted : 10/03/2013 2:57 pm
Thrustyjust-Not tempted to go one(maybe 2) size up at all? 😉
Posted : 10/03/2013 3:02 pm
I did question the size, but the standover is the same as my Cube and also the top tube is the same, so going bigger meant a longer reach . This was recommended by Dolan. Guess as being a compact frame it shows more post. The seatpost comes with the frame and has a good 2 1/2 inches to go before reaching its stop limit.
Used to riding old style road bikes with tiny posts showing , so seemed a bit different, but then my Cube is the same.
Posted : 10/03/2013 3:14 pm
The Cube's are particularly short in the tt.I'd end up going Up a size or 2!!
Posted : 10/03/2013 3:18 pm
At the risk of sounding uneducated / controversial how much difference does bike weight make to the average amateur rider? My £800 tiagra equipped 10 / 10.5 kg base model road bike seems to do me well enough - I'm just curious if its marketing hype or willy waiving? Don't get me wrong I'm not criticising anyone for spending ££££s on a road bike I'm just curious what the actual improvement in performance is?
I see the benefit of expensive light weight / quick rolling wheels but struggle to see what difference overall bike weight makes when many of us weigh upwards of 180lbs?
Posted : 10/03/2013 4:50 pm
 mrmo
light is nice, and there is an element of mind games that shouldn't be ignored,
Posted : 10/03/2013 4:53 pm
So why do you think wheel weight is significant if overall bike weight isn't?
Posted : 10/03/2013 4:58 pm
Wheel weight due to rotational weight and my belief that the lower the rotational weight the quicker you will accelerate - or have I got that wrong?
Posted : 10/03/2013 5:01 pm
Today I raced my race bike for the first time since last season, not even put a leg over it since last year.
Only ride my training bike with heavier bits.
All I can say about the difference is 'shit the bed'
Posted : 10/03/2013 5:07 pm
Will lower overall bike weight not also result in faster acceleration?
Posted : 10/03/2013 5:28 pm
Rotational weight is worth more, cos you have to rotate it and move it along.
Light wheels probably contribute to that oft used phrase "it rides lighter than the scales suggest"
Posted : 10/03/2013 9:13 pm
 seb
My Canyon F10 is at 6.8kg with the pedals.
[url= http://farm3.staticflickr.com/2748/4427416451_b72d20dc2b.jp g" target="_blank">http://farm3.staticflickr.com/2748/4427416451_b72d20dc2b.jp g"/> [/img][/url]
[url= [/url] by [url= http://www.flickr.com/people/s_perrotin/ ]Seb Perrotin[/url], on Flickr
Posted : 10/03/2013 9:24 pm
<sigh> only if you think acceleration is important. The amount of power used in acceleration is actually a very small proportion of your total power output, even if you're doing crit racing. Though let's do some numbers as well...
Open Pro, 425g
American Classic CR350 (one of the lightest readily available clinchers), 350g
So a total weight saving of 150g the pair. For a typical 75kg rider with a 8kg bike, switching from a pair of wheels with Open Pro rims to CR350s will make a difference of 0.36% to the acceleration (that's accounting for linear and rotational inertia). IIRC there needs to be a difference of at least 5% for the average human to be able to detect it even in a strictly controlled back to back test.
Remind me again why light wheels are so important?
Posted : 10/03/2013 9:27 pm
A lot of the bikes on here would be even lighter - if only they didn't have all those spacers...
Posted : 10/03/2013 10:15 pm
Sorry, better take 6 grammes off for the carbon spacers then. 🙄
Posted : 10/03/2013 10:17 pm
I dont know, leave the massive spacer stack and wait for the steerer tube to snap. They'll definitely be lighter without a stem and handlebars.
Posted : 10/03/2013 10:30 pm
I do hope that is a figure off the top of your head and you don't actually know how much they weigh? 😛
Posted : 10/03/2013 10:33 pm
I wouldn't advocate riding a bicycle that was as much unsafe as it was sportive bathchair - and think of the weight savings!
Someone must know how much a mm of steerer weighs?
Poor old Cav - his bike weighs 7.7kg! What a muppet, if only he knew...
Posted : 10/03/2013 10:36 pm
Mine weighs about 24lbs (11kgs).
Steel is real 😀
Posted : 10/03/2013 10:40 pm
I thought the weight of wheels were more important because you have to move them further. For every yard the bike moves forward the rim, tyre etc has to move nearly twice as far, what with the up and down and even backwards. So more energy savings there.
That said for the average rider doesn't a kg only equal about 10 seconds per hour? Might matter to Cav, but personally I don't even bother peddling down the hills.
Posted : 10/03/2013 11:30 pm
 mboy
In the last week, both my boss and myself have put in some miles on a Bianchi Oltre. At 6.8kg with pretty light wheels, a good 1.2kg lighter than my bike, and almost 2kg lighter than my bosses usual bike.
Both of us noticed our average speeds had gone up somewhat, and in his case he did a short reliability ride this morning in under an hour where his previous best was 1:02.
Is it the bike? Is it a placebo effect? Is it the "oh my god this is expensive, I'd better pedal hard to make it look good" factor? Probably a bit of each... Either way its an expensive way to go faster, but a lighter bike seems to work!
Posted : 11/03/2013 1:51 am
I have Pronghorn Mountain Bike and it's weight is 11.1kg (24.5lb). It's frame weight is almost 2.4 kg.
Posted : 11/03/2013 8:01 am
I've never heard that phrase in my life! 😕
I'm with aracer on the wheel difference being negligible. [url= http://www.training4cyclists.com/how-much-time-does-extra-weight-cost-on-alpe-dhuez/ ]This[/url] is some interesting reading on the subject - saving weight is good. Saving weight on your wheels is very very marginally better.
Posted : 11/03/2013 9:49 am
I probably read it somewhere like What Mtb 😳
Posted : 11/03/2013 1:16 pm
Look chaps, all this talk of marginal weight loss, and where it is, is detracting from photos of bikes on the thread.... 😉
Posted : 11/03/2013 1:30 pm
Compared to some of the bikes on here, mine is rather portly at 8kg on the nose, inc pedals and computer. Most of the excess weight seems to be in fork which is listed at nearly 600g. As much as I'd love to drop another 500g or so, I cant say the weight bothers me, it's lighter and more comfortable than the previous road bikes I've had and making the bike lighter wont really make me any faster.
Posted : 11/03/2013 1:57 pm
Another Lemond owner. Previous full steel Lemond Sarthe with full 9sp Ultegra weighted about 9.2kg. Now upgraded to a Lemond Versailles, steel and carbon mix, very nice ride, not super light, but not that heavy. Weight with Time MTB pedals is 8.9kg, which considering it's all Dura Ace and Ultegra mix (wheels are Mavic Cosmos rims on DA hubs, probably weight about 1.6kg) with reasonable finishing kit is quite heavy. Lighter frame and fork would probably get it down to low 8's. The Ti Bel Air was now replaced by a Ti Flite.
[img] https://lh4.googleusercontent.com/-4dlE0QysFno/UT4yy6cCciI/AAAAAAAAQwM/VSbw1Ua4gJs/w692-h624-p-o-k/2013-03-11 [/img]
Posted : 11/03/2013 9:04 pm
My CX/winter roadie comes in at 28lbs (13kgs)!
Posted : 11/03/2013 9:21 pm
mieszko - Is that Versailles.....carbon seatstays through the seatpost junction and then into a steel front end??
Posted : 11/03/2013 10:37 pm
Mtbtomo - it's OCLV 120 carbon top tube, seat tube and seatstays and True Temper Platinum OX bottom tube, chainstays and headtube. Kind of half carbon half steel. It's very comfortable, however it's not that light, frame is about 1.6-1.7kg so weights similar to a low/mid range aluminium frame. But it does look stunning in the flesh, the carbon has a clear coat with silver metallic flakes, looks great in sunlight. Have not seen another one like mine. 🙂
Here is the frame only I bought off here, you can see clearer the carbon and steel:
Someone on STW has a Lemond Victoire, which is like my Versailles but instead of steel it uses titanium. Ultimate Lemond frame. However I'm too poor to make him an offer he could not refuse on it. 🙁
Posted : 11/03/2013 11:11 pm
I like! 🙂
Posted : 11/03/2013 11:54 pm
I've got a Lemond Alpe d'Huez aluminium/carbon frame and forks I'd like to sell if anyone's interested. 55cm. And some other bits to go with it.
Posted : 12/03/2013 12:18 pm
Page 5 / 5
