Mate has a 185mm shock that needs to be 190mm - could he use 2 offset bushes to LENGTHEN the shock? would it make up the missing 5mm?
Posted : 08/03/2013 10:44 am
Depends on the size of the hole as to how much offset there is (more with 6mm, less with 8mm) but normally 3-6mm offset at each end.
technically you can lengthen like you say, BUT under use they often rotate back to the default position (reducing I2I) unless they are clamped uber-tight.
185mm is an odd size...shock from a Specialized?
Posted : 08/03/2013 10:47 am
from a cove to go on a prophet
really? what Cove came with a 185mm I2I shock, it's a very unusual size, I've only ever seen them on Specializeds
Posted : 08/03/2013 10:52 am
see this thread - http://singletrackworld.com/forum/topic/wtd-fox-rear-air-shock-185mm-for-a-marin-03-tara-frame
Posted : 08/03/2013 11:43 am
