How much 5wt oil in...
[Closed] How much 5wt oil in a Rev lowers
4 Users
goes in the lower legs of a Revelation 29er when reinstalling the lowers? Can't seem to find the figure in the manual.
Thanks for any advice.
Rich
Posted : 13/04/2013 9:17 am
It's actually 15wt you need for the lower legs and it's 5ml.
Posted : 13/04/2013 9:20 am
Thanks. Is that both sides of the lowers? When I dropped the lowers oil only came out of the damper side.
What about in the top cap on the air spring side? I am pretty sure the SRAM vid said 6ml 15wt in the top.
Posted : 13/04/2013 9:27 am
Yes, both sides. You're meant to just put grease in the air spring but I put about 2ml of 15wt in there just to keep the foam ring lubricated.
Posted : 13/04/2013 9:33 am
5ml of 15wt as said above - both sides.
Oil chart here:-
[url= http://cdn.sram.com/cdn/farfuture/YL3tV_-p2R7RHzoYEvE-kYZ9IWS_u4gj_2ldmQp4Ano/mtime:1340230333/sites/default/files/techdocs/gen_0000000004198_rockshox_suspension_fork_oil_chart_2013_0.pdf ]http://cdn.sram.com/cdn/farfuture/YL3tV_-p2R7RHzoYEvE-kYZ9IWS_u4gj_2ldmQp4Ano/mtime:1340230333/sites/default/files/techdocs/gen_0000000004198_rockshox_suspension_fork_oil_chart_2013_0.pdf[/url]
Service guide for 2013 Revs here:-
[url= http://cdn.sram.com/cdn/farfuture/Vz_vxWjT0hd2iE1VYLriQGgbclmztPXatKdHb4xbOcs/mtime:1352492467/sites/default/files/techdocs/gen.0000000004218_rev_a_2013_revelation_service_manual.pdf ]http://cdn.sram.com/cdn/farfuture/Vz_vxWjT0hd2iE1VYLriQGgbclmztPXatKdHb4xbOcs/mtime:1352492467/sites/default/files/techdocs/gen.0000000004218_rev_a_2013_revelation_service_manual.pdf[/url]
Posted : 13/04/2013 9:34 am
 LoCo
8 to 10ml in each leg of 15wt
Thanks chaps.
Posted : 13/04/2013 11:28 am
