How interchangable ...
[Closed] How interchangable are Avid disc adaptors?
[#1669482]
If I want to use an Avid adaptor with a non avid brake, will it bolt straight on or will I need the conical washer set up?
I've got a Tektro post mount caliper, IS fork and a 160mm rotor. I want to run a 185 rotor. Will the Avid mopunt do it or do I need the avid mount and washer kit?
Posted : 03/06/2010 12:24 pm
no one?
Posted : 03/06/2010 12:49 pm
With a bit of tinkering with washers some will work some won't
IIRC I ran a Hayes 9 caliper on an Avid 185 adaptor on my old Kona FS but didn't use the conical washers as the disk was 180mm just a small stack of plain washers to bring it to the correct height.
Last week I fitted the Hayes 9's to a friends bike using Shimano post-post adaptors and still had to shim with washers to get the correct placement on the rotor.
So to sum up "suck it and see"
Posted : 03/06/2010 12:59 pm
I do not think that you'll need the washer kit. I think that the washers are taken into account by the position of the mounting lugs on Avid calipers rather than the sizing of the adaptors. Otherwise I think that Avid brakes wouldn't work directly with post mount forks and 160mm rotors.
Actually, a quick check would suggest that my commuter's old Deore front brake is mounted using an Avid adaptor. 🙂
Posted : 03/06/2010 1:01 pm
Will fit fine. If you don't have the CPS washers - they are the same as V-brake pad washers - then you'll need to shim between the mount and the calliper but you need to do that on all makes of callipers to some extent.
Posted : 03/06/2010 1:04 pm
ChrisL, good point about the direct fitting. I know some need fettling into final position. I'm running an Avid Juicy on the rear of a bike on a 165 rotor with a stack of washers. I was just wondering whether to order the Avid 185 mount and a set of washers of the Hope 183 mount and expect to shim. Sounds like the Avid might be worth a crack first.
Posted : 03/06/2010 1:12 pm
