How far will a bike...
[Closed] How far will a bike travel in 11/34 with one pedal stroke?
am i right in thinking:
26" wheel has a circumference of 207cm
the 11/34 will give 3.09 rotations per pedal stroke/crank rotation
there fore 6.4m?
Posted : 18/12/2012 8:20 pm
You look correct so far.
This means that at 90rpm cranking you are doing 21.5mph
More than enough for flat tarmac.
PaulD
Posted : 18/12/2012 8:25 pm
cool ๐Ÿ™‚
Posted : 18/12/2012 8:31 pm
34/11 on 26'' wheels is 80.3GI, probably a little high for general riding?
Posted : 18/12/2012 8:45 pm
Pretty much spot on ^
34 x 11 on 172.5mm crank arms with a 26 x 2.25 tyre gives a gear inch of 83.4 = 6.65m for every revolution of the cranks
Not worked out in my head nor am i a gear inch bore - I used the Bike Gears app for the iPhone, pretty nifty little app that is one of the few apps i continue to use - especially in the bike shop.
Posted : 18/12/2012 9:00 pm
I can't see what crank length has to do with it.
Posted : 18/12/2012 9:23 pm
Neither can i avdave2? so here....have this award
If i mentioned Gain Ratio then i guess it would have been relevant but seeing as i didn't?....hey ho.
The original poster did not mention what crank length he was using so as most folk either use 170mm or 175mm i thought i'd be a smart arse and use 172.5 to give a median gain ratio result but as i didn't bother including the result in the above post i guess this entire explanation has been pretty irrelevant so far - fwiw the gain ratio is 6.15 so for every inch the pedal rotates around the bottom bracket the bike will travel 6.15" forward.
Posted : 18/12/2012 9:40 pm
A long way if its pointing downhill,
Posted : 18/12/2012 9:48 pm
Thank you Somafunk I have saved it with my collection of gold stars I have for eating all my tea. ๐Ÿ™‚
Posted : 19/12/2012 10:43 am
http://sheldonbrown.com/gears/
Posted : 19/12/2012 10:55 am
Well thought through; this is why I argue that very few people need a bigger gear than 34/11 or even 32/11 for anything other than road riding.
Posted : 19/12/2012 11:22 am
What would be the answer if on a 29" wheel ?
Posted : 19/12/2012 11:47 am
24.11mph
Posted : 19/12/2012 12:25 pm
No bother avdave2 ๐Ÿ™‚ , i gave myself a special "there - there" pat on the head for my cock-up regarding gain ratio.
As for the 29"? :
34 x 11 on 172.5mm Crank arms running a 29 x 2.25 tyre gives a gear inch of 89.1" = 7.11m for every revolution of the cranks with a gain ratio of 6.58
Posted : 19/12/2012 12:33 pm
The only difference crank length will make is how far your shoes travel. Hrumph! ๐Ÿ˜‰
Posted : 19/12/2012 1:43 pm
