How do you measure ...
[Closed] How do you measure yours?
Looking for a replacement seatpost and want to match existing layback. How is it measured? From centre of post to somewhere? or front of post to somewhere?
Posted : 13/02/2018 4:20 pm
Well I've got a 12 incher but I don't use it as a rule.
Posted : 13/02/2018 4:22 pm
Base to tip.
Posted : 13/02/2018 4:23 pm
 Bez
AFAIK it's centreline of shaft to centre of rail clamp.
Posted : 13/02/2018 4:24 pm
The manufacturer will tell you one thing, but it'll be different to what it actually measures, so the only way to know for sure is buy a load of seatposts and measure them yourself.
Posted : 13/02/2018 4:42 pm
AFAIK it’s centreline of shaft to centre of rail clamp.
It's normally this ^
But sometimes It's not, and even when it is you then have to take into account how big the clamp is, one post with a deep/long clamp and layback Xmm might not let you get the saddle in the same position as another post with the same measured layback but a narrower clamp if your saddle has short rails or is at extreme of adjustment
Posted : 13/02/2018 4:51 pm
From the hinge end
Posted : 13/02/2018 4:56 pm
