Just curious as i have had mine fitted for nearly 2yrs, back when i fitted a M761 chainset, and logic says it should be knackered by now surely? I don't ride in the Peaks or nowt but it must have over a 1000 miles on it easy.
Posted : 31/05/2010 2:52 pm
after you jetwash it.
Posted : 31/05/2010 3:10 pm
is it rough/loose?
Posted : 31/05/2010 3:13 pm
do your cranks rock in the bearings, can you pull a pedal away from the bike and make the crank move in same direction?
Posted : 31/05/2010 3:19 pm
No rocking or movement but do feel a little bit gritty. Nothing major though.
Posted : 31/05/2010 3:23 pm
It's fu%^&d your £200 cranks 👿
No movement-check
Not gritty-check
Not loose-check
Just abit of a creak 😥
Posted : 31/05/2010 4:56 pm
