Photoshop stick or they are so light they barely touch the ground anyway & float just above it
Rest it on a stone/bottle/stick then photoshop.
Either that or have a mate balance it then when they move take the picture before it falls!
This - fact, you're not able to photograph bikes if you have no friends.
Can you not make objects levitate through the power of your mind?
Tsk! You humans..... ๐
There are 2 bits of lead block glued to the back of those wheel rims ๐
Hold it up with thin thread, ie fishing line. It would be barely visible in the photo.
Balance it, quickly run into position and take a photo before it hits the ground.
EDIT: Bollocks, someone else beat me to it! ๐
Someone on this thread has it right ๐
Really thin wires holding it up from above like a Thunderbird. Totally the way I do it...
be brave, Ghostie it ๐
Get a mate to balance it then jump out of shot. I've also used a tripod and self-timer when I was on my own. Wait for the beeps and jump.
sharkattack - Member
Photoshop would be a damn sight easier though.
Hang it from a tree..
They buy a "finite area gravimetric field generator/nullifier" which runs on a couple of AA batteries and causes the local area gravity to be reduced to zero, allowing the bike to remain standing for the photo.
Or, they use a bit of string/fishing line........ ๐
put the bike on it's back then turn the camera round. ๐
You're all wrong. Clearly that bike is 50ft long and they're simply leaning the saddle against the red brick building
If its balanced, sureley it would be faling over and be a bit blurry????
jedi mind control....thats how you do it ๐
There's an old Billy Connoly sketch that explains it all............
It's all an optical illusion - we simply pay a street artist to draw the background directly on the pavement and lay the bike on it - I believe the makers of Batman in the 60's used a similar method to give the impression Adam West was sober enough to climb a rope.
Its all done with a green screen then the background is added later just like in the films.
What like this one?
[img] https://imageshack.com/i/j809072011571j [/img]
(old bike, old photo!)
A little trick I learnt many years ago ๐
What like this one?
Yes, although that one does look a bit as if it is about to fall over..............
What like this one?
Looks like the pedal is on an upturned glass.
Fatbikes genuinley do stand up on their own.
[url= https://farm8.staticflickr.com/7400/9338380662_0f60f19833_z.jp g" target="_blank">https://farm8.staticflickr.com/7400/9338380662_0f60f19833_z.jp g"/> [/img][/url][url= https://flic.kr/p/fecDe9 ]2013_0721sandyas****0066[/url] by [url= https://www.flickr.com/people/18504429@N00/ ]multispeedstu[/url], on Flickr
All the studio shots at Bespoked were held up by helper who let go for a few seconds on command from photographer. No bikes or helpers were injured.
OP: That bike belongs to Dynamo.
Claude Rains* is quite good at track stands.
* other invisible men might suffice
I go up a hill on a really windy day and balance the bike against the wind while I take a photo...
[url= https://farm4.staticflickr.com/3214/2384621587_62bf306fde.jp g" target="_blank">https://farm4.staticflickr.com/3214/2384621587_62bf306fde.jp g"/> [/img][/url][url= https://flic.kr/p/4CHNVi ]Cotic Soda[/url] by [url= https://www.flickr.com/people/85367853@N00/ ]simondbarnes[/url], on Flickr
The first time some magazine guys took some pics of our bikes they they described it as a 'drop shot'. It took 2 of them and it was suggested I might want to look away when they did it!
[s]A bent piece of wire supporting the rearward facing pedal work, generally hidden by the rear tyre. Better than letting go IMHO.
Stick under pedal hidden by tyre ๐
Gravity.....
You sir, are a genius
Bravo Chip, you go it ๐
There was a thing in the "outro" bit of a pretty old issue of Singletrack, probably around 2004, where they had a little behind the scenes shot of Dave Anderson holding onto a wheel on one side and someone holding onto the wheel on the other side waiting for the photographer to yell "now" so they could jump out of the way.
Mark - Resident Grumpy
This, watched the man demonstrate it(Scott bikes in Verb)
