How do my forks com...
[Closed] How do my forks compare? Fox Float 32 Evo RL
I've got a set of 2012 Fox Float 32 Evolution Open Bath Damping 150mm RL.
How do these compare to more modern forks? Anything I am missing out on? I'm going to swap my frame (still sticking with 26" for now) and wondering if I should think about changing the forks too. I'd buy second hand most likely.
On the list for possible replacements are:
Fox 34s
Rockshox Pike (new version)
Rockshox Revs
Any other Rockshox
Manitou Mattoc
Xfusion Slant
Posted : 13/02/2017 12:50 pm
Found this - [url= https://www.merlincycles.com/blog/which-rockshox-fork-is-for-you/ ]https://www.merlincycles.com/blog/which-rockshox-fork-is-for-you/[/url]
Is there an equivalent for Fox forks, or even something that compares Fox and RS?
Posted : 13/02/2017 1:44 pm
What makes you want to change what you have?
IMO, the tuning and maintenance of a fork has more impact that the shiniest, newest damper technology.
Posted : 13/02/2017 1:52 pm
I found Fox 32's at 140 mm pretty flexy so I'd imagine at 150 mm they're OMG wibbly. I'd be looking at changing for that reason personally.
Posted : 13/02/2017 1:56 pm
The forks I had prior to these were Fox Float 32 140mm and they were wibbly in comparison! I didn't realise how much I relied on/compenstated for the flex until I moved to the current ones, which seem a lot stiffer but it's all relative
Really that's the reason for starting this thread. I think my main reasons are that Fox have to be serviced so often, they are straight steerer, simple damping and no much other adjustment. Also might be Wibbly, I have nothing else to compare them to
Posted : 13/02/2017 2:34 pm
I went from Fox 32's to the Pikes and the extra stiffness is very noticeable, however I don't think they are as plush as the Fox.
Not sure that helps as this sort of thing is quite subjective.
Posted : 13/02/2017 2:44 pm
The same fork chassis at 140 travel were more flexy than at 150 travel? eh?
Posted : 13/02/2017 9:10 pm
Worth changing to 34's (post 2014) or Pikes, not so much the Revs. Can't comment on the others.
Posted : 13/02/2017 9:13 pm
Yes. But the 140mm were QR and 2010 model, the 150mm are 15mm axle and 2012. So not a direct comparison, granted.
For Fox 34, which damper is worth looking at?
Posted : 13/02/2017 10:28 pm
