How do I take off t...
[Closed] How do I take off this bottom bracket
Unsure how how to take this off, off a 1980’s cruiser.
Does it just unscrew or am I meant to be looking for any locking clips or suchlike?
probably a really dumb question but only ever dealt with square taper or hollowtech
Thanks in advance clever people
[url= https://s8.postimg.cc/bpmd22o9h/65792_E6_F-6_A55-4_A90-8_EFB-_E212_B35_CAABB.jp g" target="_blank">https://s8.postimg.cc/bpmd22o9h/65792_E6_F-6_A55-4_A90-8_EFB-_E212_B35_CAABB.jp g"/> [/img][/url]
Posted : 25/08/2018 2:56 pm
 mm93
Pedal off,nut off,ring off then crank slides through .
Posted : 25/08/2018 3:13 pm
Sounds simple enough, thanks!
Posted : 25/08/2018 3:14 pm
As said pedal off, undo the large nut (anticlockwise) remove washer, unwind large cone nut, slide crank through the bottom bracket, also remove the caged bearings, if your lucky they will still be in the cage and not go anywhere
If also removing the cups then get an old extension bar place through the bottom bracket on to the back of the cup and tap with a hammer all the way round to force the cup out of the frame
Haven't seen/had to work on a bmx with a 1 piece crank and unsealed bottom bracket since 1995!!!
Posted : 25/08/2018 3:22 pm
Looks like an Ashtabula 1 piece (press fit cups)  rather than threaded cups
Park how to has pictures, instructions and a video;
https://www.parktool.com/blog/repair-help/bottom-bracket-service-one-piece
Roughly;
Remove the LH pedal
Removed the lock nut
Remove the washer
Undo the adjustable cone
Remove the bearing
Remove the crank arm
If things are seized then some penetrating fluid/patience/skill/heat/hammer/chisel/cutting etc as required
Posted : 25/08/2018 3:23 pm
Getting those undone was never a problem in the 80's on all my BMX's,  They usually came undone all on their own every few days.
Posted : 25/08/2018 4:11 pm
"Getting those undone was never a problem in the 80’s on all my BMX’s,  They usually came undone all on their own every few days."
Like everything there's a nack to doing them up right ---like an old threaded headset .
Once you nail that they stop coming loose .
Posted : 25/08/2018 4:51 pm
Nice big bearings in those.
With a bit of development they could have been much better than the UK system.
Posted : 25/08/2018 10:17 pm
