How do I remove a h...
[Closed] How do I remove a huge logo from a tire sidewall?
 JoeG
I just bought some really cheap Kenda Nevegal tires for a retroish bike (1998 Mountain Cycle San Andreas). But the tires have huge logos "KENDATIRE.COM" on them, which will look out of place on a late 90s bike.
I know that sponsored racers just use a black marker to cover the logos, but is there a way to remove them?
Posted : 05/11/2014 7:03 pm
or
Posted : 05/11/2014 7:06 pm
Just burn them off with a lighter.
Posted : 05/11/2014 7:07 pm
Shave the Beast!
Other brands of razor are available
Posted : 05/11/2014 7:11 pm
This is STW for heavens sake
If you're going to shave it off, then make sure you use DE, not one of those nasty multi blade jobbies!
Posted : 05/11/2014 7:13 pm
Acetone should do the trick , but not sure if it will affect the rubber.
Safer option is t-cut and lost of elbow grease.
Posted : 05/11/2014 8:48 pm
White spirit might do the trick.
Posted : 05/11/2014 9:27 pm
Acetone. White spirit not so much.
Posted : 05/11/2014 9:36 pm
 JoeG
Tried:
- Oops (gentle) paint remover
- Coleman fuel
- Carbureator cleaner (solvent)
- Brake cleaner (solvent)
- Paint stripper (solvent)
The only thing that even touch it was the solvent paint stripper. And that just made it worse by removing the black printing, and exposing more white! ๐Ÿ˜ก
Black marker FTW!
Posted : 05/11/2014 10:23 pm
Just ride in mud
Posted : 05/11/2014 10:31 pm
Just ride [s]in mud[/s]
Posted : 05/11/2014 11:01 pm
 Yak
Leave it. Internet was in full swing by then.
Posted : 05/11/2014 11:31 pm
 JoeG
Bike will get ridden, but not a lot as its a retrobike. ๐Ÿ™‚ And definitely not in crap weather!
Marker obliterated the huge .com logos but left the smaller ones. Even though the interweb existed, tires generally didn't have the humungous logos seen today...
Posted : 06/11/2014 6:25 am
 Pook
When you ride it just make dial up noises
Beeeeeeeeeebooooooooooooddddddddddd
ddddddddde
eeeeeeeiiiiiiiiiiiiiiiiiipip
ipipipb
eeeeeeeeeeedongdongb
eeeeeeeeeeeeee
Posted : 06/11/2014 7:03 am
Sounds like a lot of hassle, why not buy a new bike to go with the tyres?
It's kinda obvious when you think about it.....
Posted : 06/11/2014 8:30 am
Ah - 56Kb MODEM there, Pook - is that the right era for the bike??
Rachel
Posted : 06/11/2014 9:15 am
