How do I know if I ...
[Closed] How do I know if I can fit an Ispec shifter?
So I e got some 2014 XT brakes that came on a trek Remedy 9 and I need a new rear shifter.
How do I know if I can use an Ispec shifter? Or do I just get a clamp one?
I'd rather the space be freed up for the reverb.
Posted : 07/02/2016 8:11 pm
You should be able to fit Ispec B to those.
Posted : 07/02/2016 8:18 pm
I just found a review of the bike saying that they wished they'd specced Ispec to the bike.
Posted : 07/02/2016 8:21 pm
[url= http://www.chainreactioncycles.com/shimano-xt-m785-disc-brake/rp-prod67208 ]Is it these XT brakes you have?[/url] - if so then they are ISpec B compatible
You can fit [url= http://www.chainreactioncycles.com/shimano-xt-m780-10-speed-trigger-shifter/rp-prod69488 ]this XT Rear I-Spec B 10speed shifter[/url] but if you have 11 speed on your bike then you'll need to buy [url= http://www.chainreactioncycles.com/shimano-xt-m8000-11-speed-trigger-shifter/rp-prod135894 ]this XT M8000 I-Spec B 11 speed shifter[/url]
Posted : 07/02/2016 8:23 pm
Mine are m785 - b
I assume the b means Ispec B right.
Posted : 07/02/2016 10:03 pm
Yep, make sure and get the corresponding ISpec B shifter and you're good to fettle.
Posted : 07/02/2016 10:11 pm
