bought some judys and need to identify them for a service.
they are;
mettalic red.
say race on a sticker inside the leg
have IS disc mount and vee bosses.
100 mm travel - sprung.
two black adjusters on the tops of stachions.both the same.
dont think they lockout.
any ideas and any numbers on them that would identify them?
they are 2001 models
are you sure they have 100mm (2001 race normally 63/80)
Were not the older Judy DH forks (about 1998) red & 100mm travel? Could it be some of those?
well i was told they were 100mm.......
as i say they have race written on a sticker on the inside of the legs and some world cup stylee coloured flashes..
and judy on the outside of the leg with some black swirly bits benind.
oh and the crown area is red also
oil in the left leg and spring in the right i belive..
red crown defo 2001
any advance on 2001 or can anyone say what year they are def not?
2001
Pics?
will try and do pics.have never put on here before.is it simple?
Click IMG and paste in your 'properties' from flickr or wherever you use. Newer RS have a year stamped/forged on the inside of the arch.
upload it to tinypic and paste the 'forum' link in your post (including the img tags)
ok so i need to be on flickr or something like that yes?
ps if it is a 2001 fork any good links to overhaul info...
and any good sources for fork oil...
thanks in advance.
bump
cut the stanchion in half and count the rings?
2001 was my first inclination, although I'm not sure if the WC 'flashes' weren't added in 2002, trying to think if my 2001 SIDs had them!
Certainly that era.
2001
lol mrnutt.
fork oil.... DO NOT GO TO THE LBS... pop to your local motorcycle shop same stuff half the price, you would need to know what weight oil your after, but its probably 5w.
so ive been googling around abit and found a pic of 2001 judys.they look much older than mine.they have fork boots and mine dont.
they are fire engine red and mine are metalic red/marroon.
the bridge bit is quite small. on mine its large and flattenned quite a lot.
can any one update this as i need to service these bad boys...
get a pic up.
They sound like Judy 100's to me, circa 1999.
Had some on an Orange MsIsle, 99 as that's when XT went 9 speed IIRC.
Oh sorry metallic red, not those then.
its not actually red but metalic MAROON. this may hopfully eliminate the older judy's with shock boots that were painted pillar box red.its not them!
think this should link to a pic.if it works these are exactly what mine look like!!
http://www.epinions.com/bike-Forks-All-Judy_Race
some one must have owned them....
