how do I get into m...
[Closed] how do I get into my hub...
unbranded rear hub from a specialized secteur comp. bearings have started rumbling.
there is a grub screw on the non-drive side
there is grub screw just inside the cassete carrier on the drive side.
undoing these doesnt seem to free anything up?
any ideas or suggestions?
Posted : 27/06/2012 10:49 pm
Any pics???
Posted : 27/06/2012 10:51 pm
its dark and its in the shed now.
i should note that I haven't tried hitting it with a hammer yet.
Posted : 27/06/2012 10:53 pm
Hold off with he hammer and get a pic on and il let you know
Posted : 27/06/2012 10:55 pm
possibly threaded also.
Posted : 27/06/2012 10:57 pm
I thought that but no flats or similar to undo with.
Posted : 27/06/2012 11:11 pm
they can be pretty stiff to pull off...vicar...
Posted : 27/06/2012 11:13 pm
[url= http://farm9.staticflickr.com/8157/7466114260_5b6035de65_z.jp g" target="_blank">http://farm9.staticflickr.com/8157/7466114260_5b6035de65_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/jambo_uk/7466114260/ ]Untitled[/url] by [url= http://www.flickr.com/people/jambo_uk/ ]jambo-uk[/url], on Flickr
[url= http://farm8.staticflickr.com/7117/7466113736_dd3f11665c_z.jp g" target="_blank">http://farm8.staticflickr.com/7117/7466113736_dd3f11665c_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/jambo_uk/7466113736/ ]Untitled[/url] by [url= http://www.flickr.com/people/jambo_uk/ ]jambo-uk[/url], on Flickr
Posted : 29/06/2012 12:36 pm
 Del
pull.
Posted : 29/06/2012 12:40 pm
pull hard
Posted : 29/06/2012 12:49 pm
Before you do either of the obove suggestions ๐Ÿ™„ I'd try undoing those grub screws first, if that's indeed what they are. Just pulling blindly is gonna knacker stuff. ๐Ÿ™‚
Posted : 29/06/2012 12:55 pm
Before you do either of the obove suggestions I'd try undoing those grub screws first, if that's indeed what they are. Just pulling blindly is gonna knacker stuff.
Ignore the above, two shire horses is what you need, pull blindly, what could go wrong?
Posted : 29/06/2012 1:00 pm
i've undone the grub screws and nothing is moving easily. i put them back in so I don't lose them.
pulling is all very well but there's not a lot of purchase to pull with...
Posted : 29/06/2012 1:01 pm
 ton
soft jawed vice or a vice with some padding to stop damage .
Posted : 29/06/2012 1:04 pm
 Del
also i took
to mean that the grub screws were undone.
if you grip on the silver ( anodised? ) bit you're less likely to mark it, but one end in a vice and the other held in pipe grips or similar, give a bit of a twist if you like may help free things off.
Posted : 29/06/2012 1:34 pm
Cool. Ignore me. I refer you back to SFB! ๐Ÿ™‚
Posted : 29/06/2012 1:36 pm
Alternatively, try hitting the axle with a hammer, which should drive the axle complete with one side bearing out......
Posted : 29/06/2012 1:37 pm
yes he said he'd already undone them so I didn't say to do it again ๐Ÿ™‚
Posted : 29/06/2012 1:45 pm
Simon, I only skim read down to the pics. Bad Poddy. ๐Ÿ˜‰
Posted : 29/06/2012 1:47 pm
try the big hammer
Posted : 29/06/2012 2:03 pm
Loosen grubscrew on one side, tap axle with a hammer on that side, axle and alloy collar should come off to the other side. Might need a reasonable tap depending how tight the press fit is.
Posted : 29/06/2012 2:06 pm
wearing ear defenders enables you to hit hard enough without distress
Posted : 29/06/2012 2:08 pm
 Del
or at least, distress to oneself.
Posted : 29/06/2012 2:16 pm
My thinking would be that the grub screws are there for a reason,so take them out and put them somewhere [u]SAFE[/u] ๐Ÿ˜‰ Get two sets of Pipe grips,some wet and dry and some tape.Wrap the tape round the ends ,then wrap the wet and dry round the tape.
On with the pipe grips and rotate opposite ways ...Good luck ๐Ÿ™‚
Posted : 29/06/2012 2:25 pm
