how do i get 2x10 w...
[Closed] how do i get 2x10 working on a giant trance x?!
If I have the front mech in the right place over the chainrings, it hits the linkage 75% into the rear travel. If I raise it up then I have poo shifting and the chain rubs the bottom bit of the mech when I ride in the granny ring.
Anyone know what front mech I need or what black magic is required to make it work?
ta
Posted : 08/06/2015 11:46 am
 br
[i] and the chain rubs the bottom bit of the mech when I ride in the granny ring.[/i]
If this is just in the smaller rear cogs, don't use them - if all cogs then no idea.
Is it a 2x specific mech/shifter, or have you configured a 3x one?
Posted : 08/06/2015 12:35 pm
b r - Member
Thanks, it's an M531 mech which said it was okay for 2 and 3 rings (albeit 9sp but I don't think that makes a difference?)
I think it rubs in all except the biggest rear cog.
I was thinking a top pull type mech might be better but this frame has a bend in the seatpost so not sure it'd line up right.
Posted : 08/06/2015 1:36 pm
What year is the bike?
You could try a 9 speed slx (m665) double specific front mech, has a shorter cage, no issues on my mates 2009 Trance.
Re:- your triple, if you've moved it down put it back in the original position it was in before you removed the big ring, you'll have a large gap between middle and front mech but thats just how it is unless you fit a double specific.
Posted : 08/06/2015 3:24 pm
2011 frame I think, I'll see about getting a double specific mech.
Thanks
Posted : 08/06/2015 5:26 pm
My 2010 Trance X had the same problem when I first built it, easily solved it by turning the mech a few degrees towards the back of the bike.
Just make sure the mech doesn't foul on the linkage during full compression.
Posted : 08/06/2015 8:11 pm
