...when the screw heads have gone?
anyone got any ideas?
drill head off bolt, remove rotore, remove stube with mole grips/vice
Cut a new head slot with a hacksaw then loads of wd40 or similar and an impact driver
I gave mine to my local engineer chap (he rides an Orange 5) and he sort of drilled it out somehow.
Happy to help.
Angle grinder and a big screw driver works for me
Thanks guys. Will give your suggestions a go. Wish me luck!
Good luck!
Cutting slot and screwdriver always works for me!
Can you do us a picture? Last time I remember a thread like this the guy had centre lock rotors which look remarkably similar to 6 bolt rotors except the instead of bolts you get fasteners that look like the heads have been removed.
If you can't do a picture then are they shimano? Did they come on the bike or did you put them on yourself?
Are they rounded allen key heads?
If so, take a torx fitting & drive into the bolt head, should then enable removal - allen key head knackered anyway.
Additional to screwdrive technique above - did this once & still couldn't undo...so I used a set of molegrips on top of the screwdriver to enable greater leverage - worked a treat.
Last time I just sawed 2 sides parallel to each other into the bolts so mol-grips could clamp round them and hey presto, easy off!
