How big is a casset...
[Closed] How big is a cassette lockring tool nut?
I have a Cyclo branded cassette lockring tool that has a hex nut with which to turn it. For removing the cassette a long adjustable spanner is just dandy but I can't find a socket that's the right size to fit it so I can attach my torque wrench for fitting the new cassette.
The nut appears to be the same size a Bikehut and Park tools version of the same tool.
A 24mm is too small and a 27mm is too big. I assume I need an imperial 1" socket?
Does anyone know what size socket I need?
Posted : 21/02/2011 8:06 pm
Erm measure your tool? ๐Ÿ˜‰
Posted : 21/02/2011 8:07 pm
 mc
1" IIRC.
Posted : 21/02/2011 8:09 pm
It's about 1" across (which is why I thought I might need a 1" socket) but I assumed that it would be metric.
I rather hope it is imperial, all this dodgy metric measurement is far too complicated ๐Ÿ˜‰
Posted : 21/02/2011 8:10 pm
just checked and I'm using a 15/16ths socket..... there's a tiny bit of movement so prob not 1"
Posted : 21/02/2011 8:21 pm
 mc
15/16" AF = 23.81mm.
I know the lockring tool is the same size as the hex cut out on the park chain whip, but for removal I'm sure I normall use a 1" spanner, although I used an adjustable the last time.
Posted : 21/02/2011 8:27 pm
15/16" AF = 23.81mm
In this case mine can't be 15/16 AF as a 24mm socket's too small
Posted : 21/02/2011 8:44 pm
Mine works perfect with a 1" spanner and nearly as good with a 26mm socket (a bit loose).
Posted : 21/02/2011 8:45 pm
