Hot 1.25Gbps 1310nm...
[Closed] Hot 1.25Gbps 1310nmT 550nm 2Km SFP transceiver module for sale
The small form-factor pluggable ([url= http://www.ingellen.com/fiber-optic-transceiver-sfp-fiber-optic-transceiver-c-1_2.html ]SFP Fiber Optic Transceiver[/url]) is a version of Mini-GBIC. It supports data rates up to 10 Gbit/s. The SFP Fiber Optic Transceiver are available with a variety of transmitter and receiver types. And here, let introduce hot 1.25Gbps SFP Module for all, just like 1.25Gbps 1310nmT 550nm 2Km SFP transceiver module.
Ingellen's [url= http://www.ingellen.com/inspl35bx-125gbps-1310nmtx1550nmrx-2km-p-46.html ]1.25Gbps 1310nmT 550nm 2Km SFP transceiver module[/url](INSPL-35-BX) series module is high performance, cost effective modules supporting data-rate of 1.25Gbps and 2Km transmission distance with MMF. The transceivers are compatible with EN 60825-1. What's more, Ingellen INSPL-35-BX series are 100% compatible with Cisco original GLC-BX-U modules. They can be inserted in the Cisco equipments and work smoothly and efficiently. With high quality and very lower prices, our transceivers have been sold to all over the world. Lifetime warranty and good after-sales service are both supplied. The following information is the details of this product:
Features
Compliant with IEEE802.3z Gigabit Ethernet Standard
Compliant with Fiber Channel 100-SM-LC-L standard
Industry standard small form pluggable (SFP) package
Simplex LC connector
Differential LVPECL inputs and outputs
Single power supply 3.3V
TTL signal detect indicator
Hot Pluggable
Class 1 laser product complies with EN 60825-1
RoHS Compliant
Specifications
Form Factor SFP
Distance 2km
Data Rate 1.25G
Low End Case Temperature (°C) 0°C
High End Case Temperature (°C) 70°C
Diagnostics Digital
Transmitter FP
Receiver PIN
Wavelength (nm) 1310/1550
Connector LC
Congratulations! You've found the best deals for Fiber Optic Products plus many more special offer! [url= http://www.ingellen.com ]Fiber Optic Products[/url] lowest price guaranteed! If you don't interested in this product, you can check out other cheap [url= http://www.ingellen.com/fiber-optic-transceiver-c-1.html ]fiber optic transceivers[/url].
Posted : 20/02/2012 11:13 am
BYE! :mrgreen:
Posted : 20/02/2012 11:15 am
