Horizon Pro / V2 en...
Horizon Pro / V2 end caps?
[#13035152]
Does anyone know if the Pro and V2 use the same end caps?
Looking to get some torque caps - CRC have them listed for the V2's but unsure if they'll fit the Pro's
Posted : 09/11/2023 10:16 am
If you mean the Neutron V2 abd the Horizon hubs it look like they have a DIFFERENT part number according to the compatability list.
Be aware there are different ones for the drive side depending on if you have a Microspline or Hyperglide axle fitted.
RS Torque dropouts are a PITA. especially with the bearing spacer floating around in the hub, but you can tap a bearing in lightly to help keep it in place.
Posted : 09/11/2023 11:33 am
If you mean the Neutron V2 abd the Horizon hubs it look like they have the same part number according to the compatability list.
No mate Horizon V2 and Horizon Pro.
Don't want to change the spacing, just fit Torque caps for RS Forks, although not critical, they will work fine as they are
Posted : 09/11/2023 11:46 am
Looking to replace a lost end cap on a Neutron front wheel (15x100)
Would a Horizon Pro end cap work? - https://www.chainreactioncycles.com/p/nukeproof-horizon-pro-end-caps?color=silver&sizeStandard=15mm
Posted : 01/03/2024 7:55 pm
